dtxpress III more info
2003-12-18 by jmascharka
*New development round 3 zone pad adoption. ' DTXPIIISP ' real play
impression
' DTXPIIISP ' the aperture 15 inch round pad has supposed the ride
cymbal mainly. As for the pad for the former ride cymbal, it was
possible to produce the timbre which differs in the pad section and
the edge, but ' DTXPIIISP ' with furthermore by the fact that the
sensor is added to the cup section, 3 zones of the pad section, the
edge and the cup section be able to assign sound respectively, the
performance expression which is closer to the raw drum becomes
possible. Furthermore when hitting, from the detailed legato
execution where also return condition of feel and the stick quite is
close to the raw drum, hits the phrase at a stroke smoothly, you can
obtain the natural performance impression to powerful play. In
addition being to be the round cymbal, it shakes and reproduces also
feeling and hitting feeling to real. Approximately it is like -30dB
and practice stand set silent characteristic by comparison with the
acoustic drum.
*Real high hat stand installing type high hat pad of stepping on
feeling
' DTXPIIISP ' installing in the existing high hat stand, you can use
the high hat pad, it is completely new type. It can build in the
sensor of the high hat clutch and one somatotype in the round rubber
pad of 13 inches, can adjust also the open condition of the top and
the bottom. Also the weight which corresponds to the rod quite is
close to the genuine high hat, there is no strange feeling in
stepping on feeling. The stereo pad (the dual zone) being to be
specification, it reproduces also performance and the foot splash
execution which acquire high hat unique strength to real.
*The tone generator module section where it can add various
improvements
' DTXPIIISTD ' and ' DTXPIIISP ' together the sound source (drum
trigger module: The right photograph) with the treble quality which
centers cymbal sound the ripple mark and pre-setting voice were
added, furthermore real the timbre was actualized. With
ƒ"ƒ@[ƒ`ƒƒƒ‹ƒZ
ƒbƒVƒ‡ƒ" function of all the 95 tunes which add new
tune, by the fact
that the CD player is connected to the AUX terminal, choosing
favorite tune from stock CD, session (combination playing) also it
is possible to do.
*The silver color was adopted the rack system of new design
It is difficult to slide the pipe surface, the alumite processing to
which the scar is difficult to be attached was administered. In
addition because the joint part and the clamps of each pipe have
done processing which cuts the groove, the pads are held securely,
the performance which is stabilized is made possible. '
DTXPIIISTD ', from the former model ' DTXPIIISP ' corresponding to
the increase of the cymbals, from, more, it improved stability to
the compact. Concerning packing to assemble, because it is folding
system of being completed, putting out from the box, it is possible
to use directly.
Re: dtxpress III more info
2003-12-18 by emf
> impression [etc.]
J,
We owe you a serious debt of gratitude. I think that it would be a
good idea for us to add all of this information to the files section,
along with what you scan and send later. If I get a chance within the
next few days, I'll make a stab at smoothing out the translation.
Then maybe the moderators can contact Yamaha central to see whether
we can play a more official role in the transition to the III. With
NAMM just around the corner, slightly anticipatory announcements on
this board couldn't be too threatening to the mothership. On the up
side, we could generate sales.
Ed
