DTXpressII hi-hat pedal
2003-12-29 by davebooth@1stcounsel.com
I set up my new DTXpressII kit yesterday.  I've been having trouble
with the hi-hat pedal.  It's not sensitive enough.  It seems I have
to give it a really good clip for it to acknowledge I'm moving my
foot.  Especially when I'm doing a rhythm on it -- sometimes it will
not read, sometimes it will give an open cymbal sound, sometimes a
closed cymbal sound.  I can't have that kind of randomization going
on!
I tried adjusting the sensitivity screw on the front.  It helped, but
still not enough.  Any ideas to help me out, or am I going to be
forced to play hi-hat rhythm by lifting my whole foot rather than
rolling on the ball of my foot?  OR do I have a defective pedal?
Premium Accounts for Legal Professionals
http://1stcounsel.com/
Re: DTXpressII hi-hat pedal
2003-12-29 by emf
will
> on!
but
Hi Dave,
Last time I looked the DTXpress had two main settings for hi hat--
"offset" (a kind of sensitivity) and "sensitivity" proper. The
former, which is located in the Utility mode, determines how much
pressure is needed to activate the foot pedal. A low value creates a
quick response (it seems like you need to go lower). The "T" setting
(detect time) on the same line determines what sound occurs when the
pedal moves. The higher the value, the more likely the result will be
a foot splash (an open sound) rather than a "chick" closed sound. You
need to fine tune these parameters. I generally had no need of a
splash, so I usually set T low enough to make it nearly impossible,
and I recall that my offset time was "0." The sensitivity setting,
located in the common parameters of the Voice Edit mode, affects
pedal action as well. Fiddle with it until it suits you.
Ed
