RE: [DTXpress] Re: 3-ZONE Cymbal Pads ??? are there any? why aren 't there any?
2004-01-14 by rdamon@mckinney-usa.com
> From:	feefer2 [SMTP:feefer2@...]
> Sent:	Tuesday, January 13, 2004 11:15 PM
> To:	DTXpress@yahoogroups.com
> Subject:	[DTXpress] Re: 3-ZONE Cymbal Pads ??? are there any? why
> aren't there any?
> What I was asking was what 'trigger type' setting you selected on
> the module's trigger selection menu.   You can end up with
> interesting results when mixing and matching pads with different
> designs with different 'pad type' settings on the module.
Chris,
On the Dtxpress module, you can't make a selection as to the type of trigger
input you want the module to sense, in the sense of it being a stereo or a
dual zone input.
Trigger inputs 1-8 are stereo inputs only. Trigger input 9/10 is a dual
input, that can be split into two mono inputs as well.
So on input triggers 1,3,4,5,8 you can plug in a mono pad or a stereo pad.
If you plug in a dual zone pad, only one zone will be detected.
On input triggers 2,6,7 you can plug in mono pad or a stereo pad or the new
3-zone Yamaha pad. If you plug in a dual zone pad, again only one zone will
be detected.
On input 9/10 you can plug in a mono pad or a dual zone pad. If you plug in
a stereo pad, only one zone will be detected.
What you are really doing is selecting pad types in the module setup not
trigger types, so that the module knows how to optimize the settings based
on the pad type entered.
OGD
The information transmitted herewith is sensitive information intended only
for use to the individual or entity to which it is addressed. If the reader
of this message is not the intended recipient, you are hereby notified that
any review, retransmission, dissemination, distribution, copying or other
use of, or taking of any action in reliance upon, this information is
strictly prohibited. If you have received this communication in error,
please contact the sender and delete the material from your computer.
________________________________________________________________________
This email has been scanned for all viruses by the MessageLabs Email
Security System. For more information on a proactive email security
service working around the clock, around the globe, visit
http://www.messagelabs.com
2004-01-14 by feefer2
Hi OGD,
Gotcha: the input capabilities are hard-wired (although I could've
sworn the DTXTreme had selectable pad types....)
The Roland TD's inputs are hard-wired, too: changing pad types
primarily causes some trigger settings to revert to default
values.  This is done simply as an aid for those learning to
adjust trigger settings.
Chris
type of trigger
stereo or a
> dual zone input.
dual
stereo pad.
pad or the new
one zone will
> be detected.
you plug in
setup not
settings based
> OGD
intended only
reader
notified that
copying or other
is
error,
computer.
MessageLabs Email
security
