Do the new DTXpress III's have an improved sample rate?
2004-04-02 by zapaxe
I own the DTXpress I and was wondering if the new line in addition
to the so called new & improved samples (especially for the cymbals)
also includes higher sample rates.
I record my set on Cubase at 24 bit with 32 bit floating point.
Compared to some other samples I've heard from people using software
drum samples, the DTXpress samples don't measure up in quality.
I'm considering upgrading to at least the DTXpress III 'Special'
set. I've also been eye-balling the new DTXtremeIIS for the extra
outputs and sampling capability.
Thanks, Steve
RE: [DTXpress] Do the new DTXpress III's have an improved sample rate?
2004-04-02 by rdamon@mckinney-usa.com
There is a new PDF brochure on the Yamaha site about the Dtxpress III and
Dtxtreme IIS.
http://www.yamaha.com/yamahavgn/Documents/Drums/DTXIIS_DTXIII_Bro_0204.pdf
<http://www.yamaha.com/yamahavgn/Documents/Drums/DTXIIS_DTXIII_Bro_0204.pdf>
OGD
The information transmitted herewith is sensitive information intended only
for use to the individual or entity to which it is addressed. If the reader
of this message is not the intended recipient, you are hereby notified that
any review, retransmission, dissemination, distribution, copying or other
use of, or taking of any action in reliance upon, this information is
strictly prohibited. If you have received this communication in error,
please contact the sender and delete the material from your computer.
______________________________________________________________________
This email has been scanned by the MessageLabs Email Security System.
For more information please visit http://www.messagelabs.com/email
Re: Do the new DTXpress III's have an improved sample rate?
2004-04-02 by emf
cymbals)
software
By and large, no module out there can compete for sound with software
samplers. The only one that rivals them in my experience is the ddrum
(I have yet to hear the TD-20 or DTXTUIIS), and even its sounds are
compressed in such a way that truncation and distortion are often in
evidence. What modules have going for them first and foremost is
convenience. When the manufacturers get more creative with sticking
nuances and raise the bit and sampling numbers, maybe the situation
will change.
2004-04-03 by zapaxe
III and
> Dtxtreme IIS.
4.pdf
04.pdf>
> OGD
Great, thanks very much! Steve
intended only
the reader
notified that
or other
is
error,
computer.
_
System.
_
addition
> cymbals)
> software
extra
software
ddrum
are
in
sticking
situation
> will change.
Very interesting, thanks for the heads up! You'd think that e-drum
manufacturers would make their brains with a little more control.
Say like adding sounds from these software samplers.
Which brings to mind...The DTXtremeIIS is supposed to be able to
have sampling capabilities...this DOES mean I could load some great
software samples yes?
Steve
2004-04-03 by emf
Steve,
The manufacturers still treat drum modules as poor relations to MIDI
keyboards, which are far more advanced in features and capability.
Some of this is due to the fact that drums aren't as inherently
mathematical as keyboards and require the development of special
touch nuances, and some is due to the fact that e-drums are nowhere
near as economically profitable as synths. It's a bit like the
chicken and the egg: Drum modules won't be immensely popular among
drummers until the features are better, and the companies won't
invest in making them better until drummers start using them in
bigger numbers. Companies also seem to deliberately withhold module
features (for example, bit and sample rates) in order to make sure
that something "new" is always available for release without
exhausting the inventory of possibility. Even Yamaha has mysteriously
said that it wants to monitor sales of its new modules before it
offers a truly professional grade one.
That said, things are improving. Roland has just raised the bar a
little more, and Yamaha's impending DTXTIIS has some characteristics
that e-drummers should welcome (ddrum, though not one of the big
boys, is a simple, elegant, and realistic alternative that surpasses
them in many areas). As you say, the onboard sampling ability is one
of the things that many people want, as well as an easy way to store
and download.
Ed
drum
control.
great
> Steve,
MIDI
nowhere
module
mysteriously
characteristics
surpasses
one
store
> and download.
> Ed
Hi and thanks Ed,
I looked at the specs on the newer DTXpress III and the DTXtremeIIS
and there is no mention of the quality of the samples in terms of
Bit & sample rate. However in the sampling cababilities section they
did say something about bringing in 44 KHz (monoural)into the brain
from outside samples. Bits? Hmmm...And does that mean the samples
within the brain are at 44KHz?
The fact that they do not make this perfectly clear is a heads-up to
what you say!
I guess it's an unfortunate reality manufactureres are hold the bit
& sample rates back to ensure that they can make future sales as I'm
sure that it can't be too hard to up the bit & sample rates in their
drum brains. But in the world of digital recording & computer DAWS
the bar has been raised in this area and just about all audio card
manufacturers are making the capabilities up to 24/32 bit &
44/48/88/96 KHz sample rates.
Staying at 16 bit is just plain silly. There's been many argumants
over this, but it seems that what has won the debate is that every
single thing you do within your recording DAW will degrade the audio
signal from volume changes, applying FX'x, etc...By the time it gets
dithered to CD the sound has been noticeably degraded.
Of course one can keep it within midi till mix-down.
Someone told me about this, but I don't yet know how but I've also
considered the possibility of using/recording with the DTXpress to
midi, putting it in something like Battery and using a drum sample
CD. Inconvenient me thinks!
Steve
