QTR Curves for Canson Infinity RAG Photographique - Epson R2400 ?
Re:QTR Curves for Canson Infinity RAG Photographique - Epson R2400 ?
2010-06-13 by Clayton Price
Hi KennethL
I'm using Rag Photographique on both my 2400 and 4880. I got them
from the Canson website, and they work well, although I'll
eventually purchase  custom profiles from Eric Chan, which I suspect
will be even more accurate.
Clay Price
Re: QTR Curves for Canson Infinity RAG Photographique - Epson R2400 ?
2010-06-13 by tboleyyh
You may, but I'd go through what is supplied first. Obviously any icc oriented profile supplied by Canson or anyone else has nothing to do with curves required for QTR printing.
I'd select a paper with similar characteristics, like Photo Rag, then either relinearize and rename the curves, or simpler still, just make new "create QTR icc" profiles for your paper. Very easy, and/or easy to have someone here or at the QTR yahoo site make for you.
I find the supplied ink setups very very similar, if not identical, with a linearization put in for the specific paper.
Often, you can print fine without doing any of the above by just testing the curves supplied for other papers, on your aper. The Canson coatings are slightly unique, but not radically so.
Sounds like you may be aware of all this already...
Tyler
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "KennethL" <heliar333@...> wrote:
> Does anyone have curves for Canon Infinity RAG Photographique - for an Epson R2400.
> If not, I'll probably have to make some.
