"bobkeefer@..." <bobkeefer@...> wrote:
> ... making the transition to digital BW. I have an Epson C88+ set up with MIS continuous feed using Eboni inks, and love the prints it makes on watercolor and drawing paper. I especially love that the whole thing just works, as they say, without my having to deal with profiles and Photoshop.
No 17 or 24" printer will be as easy as the C88, if for no other reason than you'll have more ink positions to fill.
> What are my best options for a larger printer for dedicated, archival BW? Money is, of course, an issue, and I'm very happy to buy used. I like the idea of pure-carbon ink on cotton rag paper.
It sounds like you'd be a good fit for Eboni-6 or Carbon-6. Carbon-6 is simply the name I've given to the user-mixed version of Eboni-6, which is available from MIS pre-mixed.
These inksets print with the Epson driver rather well, but a simple ICC made with QTR Create ICC perfects the printing.
>... I have long sold hand-colored black and white darkroom photos, ...
As you noted later, Arches Hot Press is your ticket here. A painter and I collaborated on some B&W photo + water color works and they worked fine.
With Arches, however, you'll want to learn how to deal with QTR. Arches prints much better if the ink loads of the midtones are held down much more than the black ink, which can be very high for a good dmax. If you use Arches with an Epson K3 printer you could probably just re-linearize the profiles I've made.
> www.bkpix.com
Looks like nice work. I think the Arches with Carbon-6 will do the trick.
See http://www.paulroark.com/BW-Info/Eboni-6.pdf, and
http://www.paulroark.com/BW-Info/Ink-Mixing.pdf.
I might add that Arches HP prints much better if you go with a printer that is at least in the Epson K2 league -- 7600 - 7880. I think you'd want the ability to feed a full sheet into the printer, which knocks out the 3800 and 4800. I bought a used 7800 and have been very happy with it.
If you want warmer tones, note that the MIS PK, LK, and LLK can do that. I currently have those in my 7800. I would probably not, however, aside from a special project I have this year that requires the warmth for old photo reproductions.
Good luck with the project.
