epson 7600 not drawing ink into dampers.
2010-07-06 by atlanta1426
I recently bought a used Epson 7600 printer to dedicate to B/W.
When I got the printer to my studio and did a nozzle check the pattern was all broken up.
Tried Windex on the pads, tried flush fluid. It helped but the yellow totally quit working. Thinking that there might be some clotted ink in the lines - I used a syringe to suck all the old ink out of the lines. Then I replaced the yellow damper.
Now the machine has quit drawing ink into the dampers. On an initial fill the printer goes through all the motions but does not draw ink from any of the lines.
I have re-set the dampers a couple of times and am pretty sure they are in there nice and tight.
I'm fresh out of ideas.
Any suggestions would be appreciated.
Yes, I've seriously thought about the dumpster.
Michael Turner
Re: [Digital BW] epson 7600 not drawing ink into dampers.
2010-07-06 by Phil Morse
Phil
> Thanks,
> Michael Turner
> - By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See “Group Topic, Rules and Guidelines” in the Files section:
> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE “OWNER” AND “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  “OWNER” AND “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
Re: epson 7600 not drawing ink into dampers.
2010-07-06 by tboleyyh
sounds like there is insufficient suction during cleaning or charging cycles. That would mean the capping station is not seating well underneath the head, either it has something on it, or it has been knocked out of position, or it is very gunked up and needs cleaning.
THose would be the easiest things to rectify before looking into pump replacement or something more drastic. Doesn't hurt to replace the capping station itself eother.
Hope that helps.
Tyler
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "atlanta1426" <atlanta1426@...> wrote:
> Thanks,
> Michael Turner
2010-07-06 by Mark Savoia
Is the left end higher then the right end? Ink works via gravity.
Mark
http://www.stillrivereditions.com
> Thanks,
> Michael Turner
