larger Kirkland equivalent?
2010-09-16 by gochatunbdotca
Do any of you have a recommendation for a glossy (PK) paper that is similar in quality and value to Kirkland 8.5x11, but is larger?   I'd like something like 11 x whatever for my Epson 2200 (loaded with MIS 3D inks).   Everything seems to be either expensive or acidic (or perhaps both).
Myron
Converting Epson 2000P to B&W
2010-09-17 by John K Stacy
I decided to convert my Epson 2000P to B&W so I ordered the black, UTFS-T015-K, MIS Ebony Black, and the UTFSN-T016, MIS 2000P UTFSN "multi-black/grey.  I installed them, printed 2-3 8x10's and the printer clogged, completely.
I have gone thru a set of cleaning carts, 3-5 refills of cleaning carts, got to the point where the printer would not recognize the black carts, nor the cleaning carts (both ink lights on solid), so I purchased a set of color carts which loaded properly and was able to print a VERY bad nozzle check.
I have now emptied the color carts trying to unclog the heads (it still will not recognize the cleaning carts nor the black carts) and don't know where to turn next.  At this point, I have spent over $100 on various carts, and I'm not sure the printer is worth it.
Any ideas greatly appreciated, thanks,
John
Re: Converting Epson 2000P to B&W
2010-09-17 by Paul
I wonder how long those carts had been on the self.
The printer is a bit old, but the one I had for a while was much more reliable than the 1280.  It was made for pigments and was trouble free for me.  But, this was quite a while ago.  That inkset is an old one.
If you have a chip re-setter and can get the machine to recognize the cleaning carts, I'd probably put some Windex in the carts with the cleaning fluid and also on the parking pads.  Let the head sit in the Windex for at least a day.  Windex (or the ammonia in it) is probably your best chance of breaking up the clogs.
A 2000p would probably work fine with Eboni-6 of Carbon-6, but you'd probably want to linearize the Epson driver output with Create ICC.  If that is beyond what you're interested in, buy a 1400.
Sorry for the bad experience.  Once you get going with a good system you'll be sold on digital B&W.
Re: [Digital BW] Re: Converting Epson 2000P to B&W
Sent: Thursday, September 16, 2010 8:51 PM
Subject: [Digital BW] Re: Converting Epson 2000P to B&W
I ordered them within the last 6 months, not on my shelf more than a day or two...
Again, I ordered them within the last 6 months, should I have ordered different carts??
Why did it stop recognizing the cleaning carts??   (where do I get the proper chip re-setter? )
I have a 1400 as my wide carriage color printer, so I was trying to utilize the excess 2000P I have....I don't mind jumping thru hoops if I have a reasonable expectation of success, so I'll check out the chip re-setter and go from there......
John
2010-09-17 by Paul
I didn't mean to suggest this was your fault.
I don't know.  Sometimes junk gets on the contacts or chip.  If the carts are not registering as empty, try wiping off the chip with a dry kleenex.
http://www.inksupply.com/epson_inkjet_cartridge_chip_resetter.cfm
This is probably the one that'll work.
Good luck.
Re: [Digital BW] larger Kirkland equivalent?
2010-09-17 by Un Globe Trotteur
Myron, I have the same question. I had bought a while back some Ilford gallery smooth gloss paper. I was told it was manufactured in the same plant (swiss I think) that the original kirkland paper. The new one is manufactured in the US. I had bought a few boxes before they replaced it.
I have not had the chance to try it with my digital neg but I will now that I got a 2200. I will just take my kirland curve and apply it to the ilford without re calibrating to see if I get awesome results.
If you find anything, let me know too.
Pierre
Sent: Thursday, September 16, 2010 7:38 PM
Subject: [Digital BW] larger Kirkland equivalent?
Myron
