Calibrating an Epson 1400
2010-10-20 by Michael Jhon
Folks,
I'm struggling here to get my B & W dedicated Epson 1400 (using Eboni 6 ink) to yield quality prints.
I've done the preliminary utility work, testing nozzles and alignment.
I'm getting  a near black, but can't get past the horizontal banding, nor  clean black. (I've scanned the Tiffen Gray Scale, and print that to evaluate)
Is there anyone near Berkeley (El Cerrito) who  would be available to run me through all the correct processes to arrive at a properly calibrated output?
I'm also interested to know if printing from Photoshop is the best course.  My wife thinks she gets better images by importing the final file into a publishing program like Indesign or Pagemaker.
Any and all advice is welcome - I'm really wanting to complete this transition from the darkroom to the computer, but am finding the process very frustrating.
Michael Jhon
Re: [Digital BW] Calibrating an Epson 1400
2010-10-20 by robert fallis
On 20/10/10 19:18, Michael Jhon wrote:
> Folks,
> to evaluate)
have you set the printer to either best or photo quailty. the horizontal
banding is usually  caused by the lack of a byte. in the output info.
bob
2010-10-20 by Paul
The settings I'd start with are on page 4 of http://www.paulroark.com/BW-Info/Eboni-6.pdf
I recommend starting with the Epson driver,  then ICCs, and finally going to the QTR rip only if needed and for special papers like the uncoated watercolor papers.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, robert fallis <fallis.robert@...> wrote:
> > Folks,
> > to evaluate)
> bob
2010-10-21 by Robert
> > > Folks,
It can also depend on the size of the original, what size you are attempting to print, if it is a JPG or TIF, etc, resolution settings, ie 300 PPI...
Personally though it uses more ink, I set my printer to print at 1200 DPI, instead of 300 as I like the quality better.
IF the original has banding in it, such as in the sky, then there will be banding in the print.  Sometimes I get originals from Relatives, who did not process them correctly, with banding in the skies. In this case, I load them into an editor, capture the sky and blur it to eliminate the banding.
