Carbon ink supply
Carbon ink supply
2011-01-10 by bobtail75
Have a look at www.inksupply.com   (MIS Associates) also follow the link to the Paul Roark site
I believe that the use of the 18003MK set-up will work on the 1900 (perhaps Paul will confirm.)
You can use refillables or a CIS. MIS also do ready filled carts.
As regards clogs , there are no promises here ! I find that if the printer is used regularly and turned off between uses it is usually OK.
Chris.
