Re: Banding Issues Continue
2011-01-26 by Paul Kohl
In an answer to my request for help, John Dean sent me the following:
"Finally there is a way to go into the 10K printer menu and slow your
printer down to what I believe is called 8 pass printing that
improves quality (4 pass is the standard but not as precise). I do
this on mine as a standard procedure. I had some banding initially on
the slower print setting. But I'm using SP with Smooth Diffusion
dither. That setting did it for me."
I am using StudioPrint as he is and, following his suggestion, I
looked for the commands that would allow me to change the speed of
the head. I found it in the "Device Controls" tab where there are
choices concerned with the pass and dot size. Unbeknownst to me, I
was using "standard 1 [4 pass| Variable small]". There were other
choices, one of which was 4 Pass Normal. I changed to that one and my
banding disappeared! The print, however, darkened about 20% so I will
have to re-linearize to get more correct ink lay down.
There was no setting choices that would allow an 8 pass mode. I am
using smooth diffusion as a dither pattern.
Thank you very much, John! I don't know if the choice that I made is
the best one but it did instantly eliminate my banding problems. I
will look at the other choices and see what they might deliver.
Paul Kohl
Paul Kohl
Visiting Professor
Art, Design and Media
Nanyang Technological University
Singapore
