"Dean" <deanwenick@...> wrote:
> ... a concise description of the best practices for this setup.
> I have been using MIS UT-14 inks in a CIS from MIS in a epson 1400 connected to a mac running OS 10.6
> I have been making prints using the epson driver and I'm sure I can do better. QTR does not list my printer/ink combo so I have not downloaded it yet.
QTR will run the 1400 just fine. There are members of the QTR forum at http://tech.groups.yahoo.com/group/QuadtoneRIP/messages who have some profiles.
> I like what I get now - is there a description of how I can get the best out of this setup?
My PDF on the UT14 inkset is at
http://www.paulroark.com/BW-Info/UT14.pdf
Keep in mind that I made the UT14 to be a very flexible variable-tone, matte and glossy compatible inkset that could print a variety of tones on lots of different papers. I made some basic profiles and curves aimed mostly at the Epson driver. I assumed, probably incorrectly, that those who used QTR knew how to make profiles with it.
I thought, and still do think, that with any inkset one of the first things that one should learn how to do is "linearize" inksets or existing profiles by using QTR's tools. I think a spectro like the ColorVision Spyder3Print is definitely worth the money. See http://www.paulroark.com/BW-Info/Spectro.pdf
However, I also outlined a few procedures that would allow one to use a flatbed scanner for this purpose. See http://www.paulroark.com/BW-Info/Making_B-W_ICCs-GrayCard.pdf
Roy Harrington has now made a script for Photoshop that automates the process. It's part of the QTR download, I believe.
The curves I made for the UT14 inkset can be used to make profiles for new papers. See http://www.paulroark.com/BW-Info/Embedding_Photoshop_Curves_in_ICCs.pdf
So, in short, custom profiles that you linearize for your system is about the best way to get the most out of any inkset.
Another approach to improving your printig is to determine what papers and tones you prefer and move to an inkset that is more specialized for that particular tone and style of printing. I never actually used the UT14 inkset much because I prefer the longevity and simplicity of 100% carbon pigment printing with Eboni/Carbon-6. So, that is my primary target. For those who want to explore the full range of what digital printing can do, UT14 is better.
Hope this helps.
