Sent: Friday, August 05, 2011 6:50 AM
Subject: [Digital BW] Re: Framing without cover matte: Spacers?
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "mrgs1001" <mrgs1001@...> wrote:
> Harry, you are smart to keep the print off the glass to prevent ferrotyping where the emulsion sticks to the glass. FrameTek ( http://www.frametek.com/ ) makes both Econospace and Framespace and they have lots of great information on their website. I prefer Framespace since it clips on the glazing without the need for adhesive. It cost a little more than Econospace but you dont have to worry about the adhesive failing over time and the top spacer dropping down over the print. You can buy them in bulk directly from FrameTek and my company sells them cut to size although we do not have them on our website yet.
> If you are concerned about archival and you are not using a mat you also need to consider the frame type since your print will be near the frame. Metal is ok but a wood frame will be very acidic. You can use frame-sealing tape such as Lineco Self-Adhesive Frame Sealing Tape (L387-0151) to protect your print from the frame.
> Cheers,
> Mark
> President Frame Destination, Inc.
> http://www.framedestination.com/
Thanks, Mark, and everyone else for jumping in with valuable suggestions. It's great to belong to a community of folks so willing to help.
I also received a private message suggesting FrameTek, and it looks like the way to go. I should clear up one point though: the print is always mounted on archival matte board and is smaller than the board itself and the (metal) frame. So, the print will never be in contact with plastic at the edge of the board; only the board will be in contact with the spacer.
The motivation for eliminating the framing matte is both aesthetic and financial. I kind of like the uncluttered look of the print mounted this way. Also, with my Logan Matcutter it is difficult to get perfectly straight edges, and more importantly, perfect corners. For an exhibit of 26 prints some time ago, I therefore decided to have the matte board cut professionally by a frame shop. The machine-made cuts were indeed perfect but cost a small fortune.
Again, thanks all,
Harry
