Less toxic spray fixative: Super Seal Acrylic Sealant Spray?
2012-06-25 by Robert
Dear Fellow Photographers,
I have been doing some research, including reviewing the archive of messages on DigitalBlackandWhiteThePrint, in the hopes of finding a less toxic spray fixative (for example, less toxic than PremierArt Print Shield Spray) for prints I intend to mount on wood blocks.
"Super Seal" (manufactured by Creative Imaginations) is reportedly "environmentally friendly":
http://www.willowwolfe.ca/super-seal.html
I was wondering if anyone had any thoughts with respect to "Super Seal" product as to:
1) toxicity during the spraying process (for example, as compared to PremierArt Print Shield Spray or Hahnemuhle Protective Spray for Fine Art Inkjet Papers & Canvas);
2) effectiveness in protecting the print; and/or
3) other relevant issues.
Thanks for your help.
Bobby (Lipman)
Re: Less toxic spray fixative: Super Seal Acrylic Sealant Spray?
2012-06-25 by Paul
Thanks for the information, Bobby.
I use PremierArt Print Shield, and according to Paul Roark this spray weakens the DMax to some extent... so one of my questions about Super Seal would be to ask its effect on DMax...
I guess we'd have to try a can and see...
Paul Whiting
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Robert" <bobbylipman@...> wrote:
> Bobby (Lipman)
Re: [Digital BW] Less toxic spray fixative: Super Seal Acrylic Sealant Spray?
2012-06-25 by Charles Becker
this sounds like a water based product not solvent like the Print Shield spray so it would be "less toxic"
Sent: Monday, June 25, 2012 10:05 AM
Subject: [Digital BW] Less toxic spray fixative:  Super Seal Acrylic Sealant Spray?
Bobby (Lipman)
2012-06-26 by Robert
In response to Seth, I should clarify that the prints will not be mounted directly on the wood; rather, the wood surface will be coated with a substrate called "Golden Polymer Medium" (Gloss), which I understand is acid free and facilitates adhesion with an appropriate adhesive.
Bobby
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Seth Rossman <seth@...> wrote:
> If it is water based, it could be an issue or require many light coats.
> But, why worry about prints mounted on wood blocks, as far as
> permanence?  The wood will eat them before the atmosphere.
> Seth
Re: [Digital BW] Re: Less toxic spray fixative: Super Seal Acrylic Sealant Spray?
2012-06-26 by jimbo
Robert,
Not trying to change your path but just a FYI.....A couple of coats of gesso will also do the job. It is a very good barrier coat...
jimbo
  Sent: Monday, June 25, 2012 7:16 PM
  Subject: [Digital BW] Re: Less toxic spray fixative: Super Seal Acrylic Sealant Spray?
  Bobby
  > Seth
  No virus found in this message.
  Checked by AVG - www.avg.com
  Version: 2012.0.2180 / Virus Database: 2437/5093 - Release Date: 06/25/12
