Claria-Noritsu B&W cards
2012-07-14 by Paul
Speaking of Claria-Noritsu, I thought I'd mention that I'm using a somewhat "standard" color setup in my 1400 now.  I do use Noritsu inks for most positions instead of Claria, but the color ink arrangement gives me a good color printer plus the B&W cards I like.
For the B&W, I use QTR and make the cards with, in effect, half a black only profile and half a full color neutral profile.
For un-sprayed Claria prints on at least Epson Premium glossy paper, the neutral patches made with the color inks actually have better Color I* scores and delta-e's than do the similar neutral patches made with a black only profile.  Compare the tests at http://www.aardenburg-imaging.com/
So, I made a single QTR profile that combines BO and color for Claria/Noritsu and the 1400.  I use it for the Red River Polar Pearl Metallic cards I like.  The light color inks smooth the BO sufficiently, and the BO reduces the color shifts sufficiently that the resulting cards are fine.  So, one of my 2 1400's is a color dye printer that also makes my B&W cards.
Here are some delta-e numbers for comparable neutral patches.  These are from http://www.aardenburg-imaging.com/ tests of Color Claria, BO Claria and Cone MPS.  (I'm not sure if the columns will hold.)
Lab L     Color     BO     Cone MPS
94         2.1       2         1.7
91         2.8       3.4       2.6
75         3.2      10.5       4.1
61         4.3      13.6       4.8
44         7.1      16.2       5.9
30         7.7      15         5.3
15         3.4      11         3.2
3.6        1.3       1.1       0.9
