Making me crazy: Can't export bw conversions
2013-06-09 by Lew Schwartz
I just scanned some old color negatives for a friend and converted them to
bw. Now I'd like to export the results back to disk so I can send them
along ... BUT when I open the exported, new named files in Explorer/Windows
Viewer they're still in color!!!! If I open them in Bridge ... they're bw
as they should be.
What to do except scream?
-Lew Schwartz
Re: Making me crazy: Can't export bw conversions
Seems to be a bug. I used the
 Image Format: Original option
Since I had also elected to rename the output files, I expected jpg's to be
written to bw jpgs and tifs to be written to bw tif's, but no such luck.
The routine ran, but nothing happened.
-Lew Schwartz
> as they should be.
> -Lew Schwartz
Re: [Digital BW] Re: Making me crazy: Can't export bw conversions
2013-06-09 by Paul Grant
Export as jpeg if they were raw originally you will get the original if that is what you expect.
Sent from my iPhone 📷
> -Lew Schwartz
> > as they should be.
> > -Lew Schwartz
Re: [Digital BW] Making me crazy: Can't export bw conversions
2013-06-10 by Kip Babington
How did you "convert" them?  Lightroom, for example, just records all
your changes in a file associated with the original, and applies those
changes when you later view the image.  But the original file itself is
not changed.  I think you have to do a "save as" to a new file name or
format in order to get a single file incorporating the changes.
> Explorer/Windows
> as they should be.
> -Lew Schwartz
2013-06-10 by Lew Schwartz
When you modify an image in LR, true, it's a non-destructive, but when you
use the export function to create a new image file, converted to another
file type or not, that new image will contain all the adjustments you made
in the editing module. This is how to make adjustments for use on the web.
That's why LR isn't a plain file type converter. It doesn't have a "Save as
...." option; you have to go through the export function to save all your
edits into a new file.
-Lew Schwartz
> to
> > Explorer/Windows
> > as they should be.
> > -Lew Schwartz
If you export as a jpg, you'll get a jpg regardless of the original format.
-Lew Schwartz
