Could be a bad 1400.
The capping station may not be sealing correctly. Mine go for months
before the Eboni shows a blocked nozzle. That said, the higher load Eboni
MK is the first to be affected by drying out.
Check and try to clean the edges of the capping station.
On Tue, Aug 20, 2013 at 10:35 AM, davidkachel <david@...> wrote:
> Every single time I fire up the 1400, whether it has been off for days or
> just overnight. The Black channel (100% Ebony) is blocked and I have to
> soak the nipple in Windex and sit the cartridge on a paper towel with
> Windex in it, for a half hour or so.
> Does anyone else have this problem? What do you do about it?
> dk
