Eboni-6 or C6b generic base in Epson 3800
2013-10-05 by <roark.paul@...>
Is anyone using Eboni-6 or the DIY version with the generic base in a 3800 or 3880? I'm trying to determine if some issues a user is having is due to the printer being different or other factors (like the source of the ingredients).
RE: Eboni-6 or C6b generic base in Epson 3800
2013-10-09 by <grimmieoldfart@...>
PHA+Tm90IHN1cmUgaWYgeW91ciBjb25jZXJuIGlzIG92ZXIgdGhlIGV4dHJlbWUgd2FybXRoIG9y IGJhbmRpbmcgYnV0IEkgcmVjZW50bHkgZXhwZXJpZW5jZWQgYm90aCB3aGlsZSBtaXhpbmcgRWJv bmkgJmFtcDsgQzZDIGZvciBBcmNoZXMuICZuYnNwO0FmdGVyIGEgZmV3IGRheXMgb2YgdG95aW5n IHdpdGggaXQgSSBvcmRlcmVkIGEgY29tcGxldGUgRWJvbmktNiBzZXQgZnJvbSBNSVMgdG8gc2Vl IGlmIHRoZSBpbmdyZWRpZW50cyBhcmUgb2ZmLjwvcD48cD48YnI+PC9wPjxwIHN0eWxlPSJjb2xv cjpyZ2IoMCwgMCwgMCk7Zm9udC1zaXplOjEzcHg7Zm9udC1mYW1pbHk6YXJpYWwsIGhlbHZldGlj YSwgY2xlYW4sIHNhbnMtc2VyaWY7YmFja2dyb3VuZC1jb2xvcjp0cmFuc3BhcmVudDtmb250LXN0 eWxlOm5vcm1hbDsiPlRoZSBwcmludGVyIGhhcyB3b3JrZWQgZmluZSB1cCB0byB0aGlzIHBvaW50 IHVzaW5nIHRoZSBPRU0gRXBzb24gaW5rcy4gJm5ic3A7QSA0IGRheSB0aG9yb3VnaCBjbGVhbmlu ZyAmYW1wOyBwdXJnaW5nIGJlZm9yZSBzd2l0Y2hpbmcgdG8gRWItTWsrQzZDLiAmbmJzcDtJIGFt IHBlcnNvbmFsbHkgc3VzcGVjdGluZyBhIGJhZCBiYXRjaCBvZiBDNkMgb3Igb2xkIGJvdHRsZSBv ZiBFYm9uaS1NSyBkdWUgdG8gc2hpcHBpbmcgJmFtcDsgbW92aW5nIGFyb3VuZCB0aGUgd29ybGQu Li48L3A+IDxkaXYgY2xhc3M9Inlncm91cHMtcXVvdGVkIj48YnI+PGJyPi0tLUluIERpZ2l0YWxC bGFja2FuZFdoaXRlVGhlUHJpbnRAeWFob29ncm91cHMuY29tLCAmbHQ7ZGlnaXRhbGJsYWNrYW5k d2hpdGV0aGVwcmludEB5YWhvb2dyb3Vwcy5jb20mZ3Q7IHdyb3RlOjxicj48YnI+PGRpdiBpZD0i eWdycHMteWl2LTc3MjMyODM2MyI+SXMgYW55b25lIHVzaW5nIEVib25pLTYgb3IgdGhlIERJWSB2 ZXJzaW9uIHdpdGggdGhlIGdlbmVyaWMgYmFzZSBpbiBhIDM4MDAgb3IgMzg4MD8gJm5ic3A7SSYj Mzk7bSB0cnlpbmcgdG8gZGV0ZXJtaW5lIGlmIHNvbWUgaXNzdWVzIGEgdXNlciBpcyBoYXZpbmcg aXMgZHVlIHRvIHRoZSBwcmludGVyIGJlaW5nIGRpZmZlcmVudCBvciBvdGhlciBmYWN0b3JzIChs aWtlIHRoZSBzb3VyY2Ugb2YgdGhlIGluZ3JlZGllbnRzKS48ZGl2Pjxicj48L2Rpdj48ZGl2PlRo YW5rcyw8L2Rpdj48ZGl2Pjxicj48L2Rpdj48ZGl2PlBhdWw8L2Rpdj48ZGl2Pnd3dy5QYXVsUm9h cmsuY29tJm5ic3A7PC9kaXY+PC9kaXY+PC9kaXY+
Re: [Digital BW] RE: Eboni-6 or C6b generic base in Epson 3800
2013-10-09 by Paul Roark
It may be that a few have experienced issues with the pH of their water and final mixes.
In my Ink Mixing PDF <http://www.paulroark.com/BW-Info/Ink-Mixing.pdf> at footnote 14 I include the following:
"Note on pH buffering: Pigments that are stabilized in part by their electrostatic charges are somewhat pH sensitive. It’s an open question whether the marginal improvements I’ve seen in settling rate with pH buffered bases are, on net, a positive addition. Even without any further buffering, the pH stays relatively close to that of the ink, and centrifuge tests show only marginal, if any advantage to further buffering, depending on the dilution ratio. Currently the buffering I’ve used is 1% (or 2%) TEA with 0.1% (or 0.2%) citric acid. The pros and cons of this step may be explored in further depth later, but at this point, it appears additional buffering is unnecessary and may be a net negative for the more concentrated mixes. These chemicals are available at Photographers Formulary."
While I have used the C6 mixes with no buffering added (it's in the original inks) and have had good, consistent results, even distilled water can vary. Apparently it absorbs CO2 and can become too acidic. MIS buffers the water it uses due to this issue.
Whether the newer heads are also more sensitive to the pH is also an unknown.
At any rate, if you have microbanding with the home mixed generic base, MIS mixed version of the generic base, or MIS mixed Eb6 dilutions, please let me know which seems to be the source of the problem.
On Wed, Oct 9, 2013 at 2:26 PM, <grimmieoldfart@...> wrote:
Not sure if your concern is over the extreme warmth or banding but I recently experienced both while mixing Eboni & C6C for Arches. After a few days of toying with it I ordered a complete Eboni-6 set from MIS to see if the ingredients are off.
The printer has worked fine up to this point using the OEM Epson inks. A 4 day thorough cleaning & purging before switching to Eb-Mk+C6C. I am personally suspecting a bad batch of C6C or old bottle of Eboni-MK due to shipping & moving around the world...
---In DigitalBlackandWhiteThePrint@yahoogroups.com, <digitalblackandwhitetheprint@yahoogroups.com> wrote:
2013-10-10 by <grimmieoldfart@...>
PHA+SSB3YXMvaGF2ZSBiZWVuIHVzaW5nIHRoZSBDNkMgYmFzZSBmb3IgTUlTLiAmbmJzcDtJIHdp bGwgc2VlIGlmIEkgaGF2ZSBhbnkgZXhhbXBsZXMgcmVtYWluaW5nIGJ1dCB0aGluayBtb3N0IHdl cmUgY2FycmllZCBvdXQgbGFzdCB3ZWVrIG9uIHRyYXNoIGRheS48L3A+PHA+PGJyPjwvcD4gPGRp diBjbGFzcz0ieWdyb3Vwcy1xdW90ZWQiPjxicj48YnI+LS0tSW4gZGlnaXRhbGJsYWNrYW5kd2hp dGV0aGVwcmludEB5YWhvb2dyb3Vwcy5jb20sICZsdDtyb2Fyay5wYXVsQC4uLiZndDsgd3JvdGU6 PGJyPjxicj48ZGl2IGlkPSJ5Z3Jwcy15aXYtMTAxNTkwNTU4MCI+PGRpdiBkaXI9Imx0ciI+SXQg bWF5IGJlIHRoYXQgYSBmZXcgaGF2ZSBleHBlcmllbmNlZCBpc3N1ZXMgd2l0aCB0aGUgcEggb2Yg dGhlaXIgd2F0ZXIgYW5kIGZpbmFsIG1peGVzLiAmbmJzcDs8ZGl2Pjxicj48L2Rpdj48ZGl2Pklu IG15IEluayBNaXhpbmcgUERGICZsdDs8YSByZWw9Im5vZm9sbG93IiB0YXJnZXQ9Il9ibGFuayIg aHJlZj0iaHR0cDovL3d3dy5wYXVscm9hcmsuY29tL0JXLUluZm8vSW5rLU1peGluZy5wZGYiPmh0 dHA6Ly93d3cucGF1bHJvYXJrLmNvbS9CVy1JbmZvL0luay1NaXhpbmcucGRmPC9hPiZndDsgYXQg Zm9vdG5vdGUgMTQgSSBpbmNsdWRlIHRoZSBmb2xsb3dpbmc6Jm5ic3A7PC9kaXY+CjxkaXY+PGJy PjxkaXY+JnF1b3Q7Tm90ZSBvbiBwSCBidWZmZXJpbmc6IFBpZ21lbnRzIHRoYXQgYXJlIHN0YWJp bGl6ZWQgaW4gcGFydCBieSB0aGVpciBlbGVjdHJvc3RhdGljIGNoYXJnZXMgYXJlIHNvbWV3aGF0 IHBIIHNlbnNpdGl2ZS4gSXTigJlzIGFuIG9wZW4gcXVlc3Rpb24gd2hldGhlciB0aGUgbWFyZ2lu YWwgaW1wcm92ZW1lbnRzIEnigJl2ZSBzZWVuIGluIHNldHRsaW5nIHJhdGUgd2l0aCBwSCBidWZm ZXJlZCBiYXNlcyBhcmUsIG9uIG5ldCwgYSBwb3NpdGl2ZSBhZGRpdGlvbi4gRXZlbiB3aXRob3V0 IGFueSBmdXJ0aGVyIGJ1ZmZlcmluZywgdGhlIHBIIHN0YXlzIHJlbGF0aXZlbHkgY2xvc2UgdG8g dGhhdCBvZiB0aGUgaW5rLCBhbmQgY2VudHJpZnVnZSB0ZXN0cyBzaG93IG9ubHkgbWFyZ2luYWws IGlmIGFueSBhZHZhbnRhZ2UgdG8gZnVydGhlciBidWZmZXJpbmcsIGRlcGVuZGluZyBvbiB0aGUg ZGlsdXRpb24gcmF0aW8uIEN1cnJlbnRseSB0aGUgYnVmZmVyaW5nIEnigJl2ZSB1c2VkIGlzIDEl IChvciAyJSkgVEVBIHdpdGggMC4xJSAob3IgMC4yJSkgY2l0cmljIGFjaWQuIFRoZSBwcm9zIGFu ZCBjb25zIG9mIHRoaXMgc3RlcCBtYXkgYmUgZXhwbG9yZWQgaW4gZnVydGhlciBkZXB0aCBsYXRl ciwgYnV0IGF0IHRoaXMgcG9pbnQsIGl0IGFwcGVhcnMgYWRkaXRpb25hbCBidWZmZXJpbmcgaXMg dW5uZWNlc3NhcnkgYW5kIG1heSBiZSBhIG5ldCBuZWdhdGl2ZSBmb3IgdGhlIG1vcmUgY29uY2Vu dHJhdGVkIG1peGVzLiBUaGVzZSBjaGVtaWNhbHMgYXJlIGF2YWlsYWJsZSBhdCBQaG90b2dyYXBo ZXJzIEZvcm11bGFyeS4mcXVvdDsmbmJzcDs8ZGl2Pgo8YnI+PC9kaXY+PGRpdj5XaGlsZSBJIGhh dmUgdXNlZCB0aGUgQzYgbWl4ZXMgd2l0aCBubyBidWZmZXJpbmcgYWRkZWQgKGl0JiMzOTtzIGlu IHRoZSBvcmlnaW5hbCBpbmtzKSBhbmQgaGF2ZSBoYWQgZ29vZCwgY29uc2lzdGVudCByZXN1bHRz LCBldmVuIGRpc3RpbGxlZCB3YXRlciBjYW4gdmFyeS4gJm5ic3A7QXBwYXJlbnRseSBpdCBhYnNv cmJzIENPMiBhbmQgY2FuIGJlY29tZSB0b28gYWNpZGljLiAmbmJzcDtNSVMgYnVmZmVycyB0aGUg d2F0ZXIgaXQgdXNlcyBkdWUgdG8gdGhpcyBpc3N1ZS4mbmJzcDs8L2Rpdj4KPGRpdj48YnI+PC9k aXY+PGRpdj5XaGV0aGVyIHRoZSBuZXdlciBoZWFkcyBhcmUgYWxzbyBtb3JlIHNlbnNpdGl2ZSB0 byB0aGUgcEggaXMgYWxzbyBhbiB1bmtub3duLjwvZGl2PjxkaXY+PGJyPjwvZGl2PjxkaXY+QXQg YW55IHJhdGUsIGlmIHlvdSBoYXZlIG1pY3JvYmFuZGluZyB3aXRoIHRoZSBob21lIG1peGVkIGdl bmVyaWMgYmFzZSwgTUlTIG1peGVkIHZlcnNpb24gb2YgdGhlIGdlbmVyaWMgYmFzZSwgb3IgTUlT IG1peGVkIEViNiBkaWx1dGlvbnMsIHBsZWFzZSBsZXQgbWUga25vdyB3aGljaCBzZWVtcyB0byBi ZSB0aGUgc291cmNlIG9mIHRoZSBwcm9ibGVtLiAmbmJzcDs8L2Rpdj4KPGRpdj48YnI+PC9kaXY+ PGRpdj5UaGFua3MsPC9kaXY+PGRpdj48YnI+PC9kaXY+PGRpdj5QYXVsPC9kaXY+PGRpdj48YSBy ZWw9Im5vZm9sbG93IiB0YXJnZXQ9Il9ibGFuayIgaHJlZj0iaHR0cDovL3d3dy5QYXVsUm9hcmsu Y29tIj53d3cuUGF1bFJvYXJrLmNvbTwvYT4mbmJzcDs8L2Rpdj48ZGl2Pjxicj48L2Rpdj48ZGl2 IGNsYXNzPSJ5Z3Jwcy15aXYtMTAxNTkwNTU4MGdtYWlsX2V4dHJhIj48YnI+PGJyPjxibG9ja3F1 b3RlPjxzcGFuIGNsYXNzPSIiPiA8ZGl2IGNsYXNzPSJ5Z3Jwcy15aXYtMTAxNTkwNTU4MGdtYWls X3F1b3RlIj5PbiBXZWQsIE9jdCA5LCAyMDEzIGF0IDI6MjYgUE0sICA8c3BhbiBkaXI9Imx0ciI+ Jmx0OzxhIHJlbD0ibm9mb2xsb3ciIHRhcmdldD0iX2JsYW5rIiBocmVmPSJtYWlsdG86Z3JpbW1p ZW9sZGZhcnRALi4uIj5ncmltbWllb2xkZmFydEAuLi48L2E+Jmd0Ozwvc3Bhbj4gd3JvdGU6PGJy Pgo8YmxvY2txdW90ZSBjbGFzcz0ieWdycHMteWl2LTEwMTU5MDU1ODBnbWFpbF9xdW90ZSIgc3R5 bGU9Im1hcmdpbjowcHggMHB4IDBweCAwLjhleDtib3JkZXItbGVmdC13aWR0aDoxcHg7Ym9yZGVy LWxlZnQtY29sb3I6cmdiKDIwNCwyMDQsMjA0KTtib3JkZXItbGVmdC1zdHlsZTpzb2xpZDtwYWRk aW5nLWxlZnQ6MWV4OyI+CgoKPHU+PC91PgoKCgoKCgoKCgoKPGRpdiBzdHlsZT0iIj4KPHNwYW4+ Jm5ic3A7PC9zcGFuPgoKCjxkaXY+CiAgPGRpdj4KCgogICAgPGRpdj4KICAgICAgCiAgICAgIAog ICAgICA8cD5Ob3Qgc3VyZSBpZiB5b3VyIGNvbmNlcm4gaXMgb3ZlciB0aGUgZXh0cmVtZSB3YXJt dGggb3IgYmFuZGluZyBidXQgSSByZWNlbnRseSBleHBlcmllbmNlZCBib3RoIHdoaWxlIG1peGlu ZyBFYm9uaSAmYW1wOyBDNkMgZm9yIEFyY2hlcy4gJm5ic3A7QWZ0ZXIgYSBmZXcgZGF5cyBvZiB0 b3lpbmcgd2l0aCBpdCBJIG9yZGVyZWQgYSBjb21wbGV0ZSBFYm9uaS02IHNldCBmcm9tIE1JUyB0 byBzZWUgaWYgdGhlIGluZ3JlZGllbnRzIGFyZSBvZmYuPC9wPgo8cD48YnI+PC9wPjxwIHN0eWxl PSJmb250LXN0eWxlOm5vcm1hbDtmb250LXNpemU6MTNweDtiYWNrZ3JvdW5kLWNvbG9yOnRyYW5z cGFyZW50O2ZvbnQtZmFtaWx5OmFyaWFsLCBoZWx2ZXRpY2EsIGNsZWFuLCBzYW5zLXNlcmlmOyI+ VGhlIHByaW50ZXIgaGFzIHdvcmtlZCBmaW5lIHVwIHRvIHRoaXMgcG9pbnQgdXNpbmcgdGhlIE9F TSBFcHNvbiBpbmtzLiAmbmJzcDtBIDQgZGF5IHRob3JvdWdoIGNsZWFuaW5nICZhbXA7IHB1cmdp bmcgYmVmb3JlIHN3aXRjaGluZyB0byBFYi1NaytDNkMuICZuYnNwO0kgYW0gcGVyc29uYWxseSBz dXNwZWN0aW5nIGEgYmFkIGJhdGNoIG9mIEM2QyBvciBvbGQgYm90dGxlIG9mIEVib25pLU1LIGR1 ZSB0byBzaGlwcGluZyAmYW1wOyBtb3ZpbmcgYXJvdW5kIHRoZSB3b3JsZC4uLjwvcD4KPGRpdiBj bGFzcz0ieWdycHMteWl2LTEwMTU5MDU1ODBpbSI+IDxkaXY+PGJyPjxicj4tLS1JbiA8YSByZWw9 Im5vZm9sbG93IiB0YXJnZXQ9Il9ibGFuayIgaHJlZj0ibWFpbHRvOkRpZ2l0YWxCbGFja2FuZFdo aXRlVGhlUHJpbnRAeWFob29ncm91cHMuY29tIj5EaWdpdGFsQmxhY2thbmRXaGl0ZVRoZVByaW50 QHlhaG9vZ3JvdXBzLmNvbTwvYT4sICZsdDs8YSByZWw9Im5vZm9sbG93IiB0YXJnZXQ9Il9ibGFu ayIgaHJlZj0ibWFpbHRvOmRpZ2l0YWxibGFja2FuZHdoaXRldGhlcHJpbnRAeWFob29ncm91cHMu Y29tIj5kaWdpdGFsYmxhY2thbmR3aGl0ZXRoZXByaW50QHlhaG9vZ3JvdXBzLmNvbTwvYT4mZ3Q7 IHdyb3RlOjxicj4KPGJyPjxkaXY+SXMgYW55b25lIHVzaW5nIEVib25pLTYgb3IgdGhlIERJWSB2 ZXJzaW9uIHdpdGggdGhlIGdlbmVyaWMgYmFzZSBpbiBhIDM4MDAgb3IgMzg4MD8gJm5ic3A7SSYj Mzk7bSB0cnlpbmcgdG8gZGV0ZXJtaW5lIGlmIHNvbWUgaXNzdWVzIGEgdXNlciBpcyBoYXZpbmcg aXMgZHVlIHRvIHRoZSBwcmludGVyIGJlaW5nIGRpZmZlcmVudCBvciBvdGhlciBmYWN0b3JzIChs aWtlIHRoZSBzb3VyY2Ugb2YgdGhlIGluZ3JlZGllbnRzKS48ZGl2Pgo8YnI+PC9kaXY+PGRpdj5U aGFua3MsPC9kaXY+PGRpdj48YnI+PC9kaXY+PGRpdj5QYXVsPC9kaXY+PGRpdj48YSByZWw9Im5v Zm9sbG93IiB0YXJnZXQ9Il9ibGFuayIgaHJlZj0iaHR0cDovL3d3dy5QYXVsUm9hcmsuY29tIj53 d3cuUGF1bFJvYXJrLmNvbTwvYT4mbmJzcDs8L2Rpdj48L2Rpdj48L2Rpdj48L2Rpdj4KCiAgICA8 L2Rpdj4KICAgICAKCiAgICAKICAgIDxkaXYgc3R5bGU9ImNvbG9yOnJnYigyNTUsMjU1LDI1NSk7 bWluLWhlaWdodDowcHg7Ij48L2Rpdj4KCgo8L2Rpdj4KCgoKICAKCgoKCgoKPC9kaXY+PC9kaXY+ PC9ibG9ja3F1b3RlPjwvZGl2Pjxicj48L3NwYW4+PC9ibG9ja3F1b3RlPjwvZGl2PjwvZGl2Pjwv ZGl2PjwvZGl2Pgo8L2Rpdj4gICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAg ICAgICAgICAgIDwvZGl2Pg==
RE: Re: [Digital BW] RE: Eboni-6 or C6b generic base in Epson 3800
2013-10-18 by <grimmieoldfart@...>
Paul,
Which Eb6 base should we be using for the 3.5 pl heads, (Epson R2400 & 3800)?
The C6B was designed for the smaller heads such as the 1400, but what are the side effects, if any, of using C6B or C6C (Arches) in the R2400 & 3800?
Re: Re: [Digital BW] RE: Eboni-6 or C6b generic base in Epson 3800
2013-10-18 by Paul Roark
I think C6b is the best.
I know of no negative side effects of C6b. One normal paper the c version ads nothing even on a 1400. So, don't bother with that for inkjet paper. For Arches, I have not done a side-by-side of b and c on 3.5 pl printers, but I use C6b on my 7800 with Arches and it seems fine.
Whether MIS's Eb6 dilutions would be better in the 3800 is an issue I can't answer. If people are having issues with that printer and the user-mixed C6b, then a test of the MIS dilution is needed. You might want to get at least one dilution from MIS to see if you can detect a difference.
Let me know how it all turns out.
