Artisan 1430 with Eboni-6 - Blotching and inconsistend print heads
2013-10-11 by <climballday@...>
SGV5IGV2ZXJ5b25lLCA8YnI+PGJyPkkgZmluYWxseSBnb3QgZXZlcnl0aGluZyBpbiBwbGFjZSB5 ZXN0ZXJkYXksIGFuZCBzZXQgdXAgYSB1c2VkLCBidXQgZXhjZWxsZW50IGNvbmRpdGlvbiBBcnRp c2FuIDE0MzAgd2l0aCB0aGUgTUlTIEVib25pLTYgaW5rIHNldC4gVGhlIHF1YWxpdHkgb2YgdGhl IGltYWdlcyBzbyBmYXIgaXMgZ3JlYXQsIGJ1dCB3YXMgaGF2aW5nIHRyb3VibGUgd2l0aCBzb21l IGJsb3RjaGluZyBpbmsgb24gMyBvdXQgb2YgdGhlIDQgdGVzdCBwcmludHMgSSByYW4uIEkgdGhv dWdodCB0aGUgYmxvdGNoZXMgb2YgaW5rIHdvdWxkIGdvIGF3YXkgYWZ0ZXIgYSBjb3VwbGUgcnVu cywgYW5kIHRoZSBzZWNvbmQgb25lIHdhcyBwZXJmZWN0LCBidXQgdGhlbiBpdCBnb3Qgd29yc2Ug d2l0aCB0aGUgbmV4dCB0d28sIHNvIEkgZGlkIGEgY2xlYW5pbmcsIGFuZCB0aGVuIGEgaGVhZCBj aGVjaywgdGhlbiByZXBlYXRlZCB0aGF0LCBhbmQgZm91bmQgdGhhdCBJIGFtIGdldHRpbmcgaW5j b25zaXN0ZW50IHJlc3VsdHMgZnJvbSB0aGUgaGVhZCBjaGVjayBwcmludHMuIDxicj48YnI+SSYj Mzk7dmUgbm93IGRvbmUgdGhlIGNsZWFuaW5nIHRocm91Z2ggdGhlIEVwc29uIHByaW50ZXIgZHJp dmUgNCB0aW1lcywgYW5kIGRvbmUgYSBjaGVjayBlYWNoIHRpbWUsIGFuZCBlYWNoIHRpbWUgdGhl cmUgYXJlIGRpZmZlcmVudCByZXN1bHRzLiBOZXZlciBwZXJmZWN0LCBidXQgYWx3YXlzIGEgZGlm ZmVyZW50IGhlYWQgdGhhdCBpc24mIzM5O3QgcXVpdGUgcmlnaHQuIDxicj48YnI+SSBrbm93IHRo YXQgaGVhZHMgd29yaywgYXMgSSByYW4gdHdvIHRlc3RzIHdpdGggdGhlIEVwc29uIGluayBiZWZv cmUgSSBwdXJjaGFzZWQgdGhlIG1hY2hpbmUsIGFuZCBib3RoIGNhbWUgYmFjayBmbGF3bGVzcy4g QWZ0ZXIgYnJpbmdpbmcgaXQgaG9tZSwgSSByYW4gYSBjb3VwbGUgcHJpbnRzIHdpdGggdGhlIG9y aWdpbmFsIGluaywgYW5kIHRoZXkgbG9va2VkIGdvb2QgYXMgd2VsbC4gSXQmIzM5O3Mgb25seSBh ZnRlciBpbnN0YWxsaW5nIHRoZSBNSVMgY2FydHJpZGdlcyB0aGF0IEkmIzM5O3ZlIGhhZCBwcm9i bGVtcy48YnI+PGJyPldoZW4gc3RhcnRpbmcgdGhlIG5ldyByZWZpbGwgY2FydHJpZGdlcywgaWYg YW55dGhpbmcsIEkgdW5kZXJmaWxsZWQgdGhlIGNhcnRyaWRnZXMsIGxlYXZpbmcgcm9vbSBhdCB0 aGUgdG9wIChhYm91dCAxMGNjcywgd2hlbiB0aGV5IHdpbGwgdGFrZSB1cCB0byAxMiBvciAxMyBp dCBzZWVtcykuIEkgcmVwbGFjZWQgdGhlIGZpbGwgaG9sZSBwbHVncyB0aWdodGx5LCBidXQgcmVt b3ZlZCB0aGUgY2xlYXIgdmVudCBjYXBzLCBhcyBwZXIgdGhlIE1JUyBpbnN0cnVjdGlvbnMgb24g dGhlIGlua3N1cHBseS5jb20gd2Vic2l0ZS4gSSB1c2VkIGEga25pZmUgdG8gbGlnaHRseSBwdW5j dHVyZSB0aGUgcGxhc3RpYyBjb3ZlcmluZyB0aGUgYm90dG9tIGhvbGUsIGJ1dCBsZWZ0IHRoZSBw bGFzdGljIGluIHBsYWNlLCBhbmQgZHJldyBlbm91Z2ggaW5rIG91dCBvZiB0aGUgYm90dG9tIHRv IGdldCBwYXN0IGFueSBhaXIgcG9ja2V0cy4gSSBhbHNvIGxldCB0aGUgcHJpbnRlciBzaXQgb3Zl cm5pZ2h0LCB3b25kZXJpbmcgaWYgbWF5YmUgdGhlIHByb2JsZW0gd2FzIGFpciBidWJibGVzLCBi dXQgcGlja2VkIHVwIHRoZSBuZXh0IGRheSBleGFjdGx5IHdoZXJlIEkgbGVmdCBvZmYsIHdpdGgg dGhlIHNhbWUgcHJvYmxlbXMuIEkmIzM5O3ZlIGFsc28gdHJpZWQgcmVtb3ZpbmcgdGhlIGluayBj YXJ0cmlkZ2VzIGFuZCByZWluc3RhbGxpbmcgdGhlbS4gPGJyPjxicj5JIGNhbiBrZWVwIHJ1bm5p bmcgY2xlYW5pbmdzLCBidXQgSSBkb24mIzM5O3Qgc2VlbSB0byBiZSBtYWtpbmcgcHJvZ3Jlc3Mg d2l0aCB0aGF0LiBJJiMzOTttIGxvb2tpbmcgZm9yIG90aGVyIHN1Z2dlc3Rpb25zLi4uIDxicj48 YnI+VGhhbmtzLCA8YnI+PGJyPlN0ZXBoZW4=
Re: [Digital BW] Artisan 1430 with Eboni-6 - Blotching and inconsistend print heads
2013-10-11 by Paul Roark
Foreign objects on the bottom of the head sometimes gives me problems. (I suspect it's mostly dog hair in my house, and rare in any case.) The wiper blade doesn't always do it's job of removing the offending stuff. I use sewers' bias tape from Walmart, soaked with Windex, to gently pull back and forth across the head to remove whatever is there.
On Fri, Oct 11, 2013 at 10:48 AM, <climballday@...> wrote:
Hey everyone,
I finally got everything in place yesterday, and set up a used, but excellent condition Artisan 1430 with the MIS Eboni-6 ink set. The quality of the images so far is great, but was having trouble with some blotching ink on 3 out of the 4 test prints I ran. I thought the blotches of ink would go away after a couple runs, and the second one was perfect, but then it got worse with the next two, so I did a cleaning, and then a head check, then repeated that, and found that I am getting inconsistent results from the head check prints.
I've now done the cleaning through the Epson printer drive 4 times, and done a check each time, and each time there are different results. Never perfect, but always a different head that isn't quite right.
I know that heads work, as I ran two tests with the Epson ink before I purchased the machine, and both came back flawless. After bringing it home, I ran a couple prints with the original ink, and they looked good as well. It's only after installing the MIS cartridges that I've had problems.
When starting the new refill cartridges, if anything, I underfilled the cartridges, leaving room at the top (about 10ccs, when they will take up to 12 or 13 it seems). I replaced the fill hole plugs tightly, but removed the clear vent caps, as per the MIS instructions on the inksupply.com website. I used a knife to lightly puncture the plastic covering the bottom hole, but left the plastic in place, and drew enough ink out of the bottom to get past any air pockets. I also let the printer sit overnight, wondering if maybe the problem was air bubbles, but picked up the next day exactly where I left off, with the same problems. I've also tried removing the ink cartridges and reinstalling them.
I can keep running cleanings, but I don't seem to be making progress with that. I'm looking for other suggestions...
Stephen
RE: Artisan 1430 with Eboni-6 - Blotching and inconsistend print heads
UGF1bCwgPGJyPjxicj5Zb3UgbWF5IGJlIHJpZ2h0LCBidXQgaXQgc2VlbXMgdG8gbWUgdGhhdCBp ZiB0aGF0IHdlcmUgdGhlIGNhc2UsIEkmIzM5O2QgaGF2ZSBnb3R0ZW4gaW5kaWNhdGlvbnMgd2l0 aCB0aGUgdGVzdCBwcmludHMgSSByYW4gd2l0aCB0aGUgb3JpZ2luYWwgaW5rcyBhcyB3ZWxsLiBJ IGRvbiYjMzk7dCBrbm93IHRoZSBzcGVjaWZpY3Mgb2YgaG93IHRoZSBpbmsgY2FydHJpZGdlcyBp bnRlcmZhY2Ugd2l0aCB0aGUgaGVhZHMuLi4gSSBtYXkgdHJ5IGxvb2tpbmcgYXQgdGhhdCBub3cs IGJ1dCBJIGRvIGZlZWwgdGhhdCBpdCYjMzk7cyBzb21ldGhpbmcgdG8gZG8gd2l0aCB0aGUgTUlT IGNhcnRyaWRnZXMuLi4gPGJyPjxicj5iZXN0LCA8YnI+PGJyPlN0ZXBoZW48YnI+PHA+Jm5ic3A7 PC9wPiA8ZGl2IGNsYXNzPSJ5Z3JvdXBzLXF1b3RlZCI+PGJyPjxicj4tLS1JbiBkaWdpdGFsYmxh Y2thbmR3aGl0ZXRoZXByaW50QHlhaG9vZ3JvdXBzLmNvbSwgJmx0O3JvYXJrLnBhdWxALi4uJmd0 OyB3cm90ZTo8YnI+PGJyPjxkaXYgaWQ9InlncnBzLXlpdi04ODQ5NzUzNDQiPjxkaXYgZGlyPSJs dHIiPkZvcmVpZ24gb2JqZWN0cyBvbiB0aGUgYm90dG9tIG9mIHRoZSBoZWFkIHNvbWV0aW1lcyBn aXZlcyBtZSBwcm9ibGVtcy4gJm5ic3A7KEkgc3VzcGVjdCBpdCYjMzk7cyBtb3N0bHkgZG9nIGhh aXIgaW4gbXkgaG91c2UsIGFuZCByYXJlIGluIGFueSBjYXNlLikgJm5ic3A7VGhlIHdpcGVyIGJs YWRlIGRvZXNuJiMzOTt0IGFsd2F5cyBkbyBpdCYjMzk7cyBqb2Igb2YgcmVtb3ZpbmcgdGhlIG9m ZmVuZGluZyBzdHVmZi4gJm5ic3A7SSB1c2Ugc2V3ZXJzJiMzOTsgYmlhcyB0YXBlIGZyb20gV2Fs bWFydCwgc29ha2VkIHdpdGggV2luZGV4LCB0byBnZW50bHkgcHVsbCBiYWNrIGFuZCBmb3J0aCBh Y3Jvc3MgdGhlIGhlYWQgdG8gcmVtb3ZlIHdoYXRldmVyIGlzIHRoZXJlLjxicj4KPGRpdj48YnI+ PC9kaXY+PGRpdj5QYXVsPC9kaXY+PGRpdj48YSByZWw9Im5vZm9sbG93IiB0YXJnZXQ9Il9ibGFu ayIgaHJlZj0iaHR0cDovL3d3dy5QYXVsUm9hcmsuY29tIj53d3cuUGF1bFJvYXJrLmNvbTwvYT4m bmJzcDs8L2Rpdj48L2Rpdj48ZGl2IGNsYXNzPSJ5Z3Jwcy15aXYtODg0OTc1MzQ0Z21haWxfZXh0 cmEiPjxicj48YnI+PGJsb2NrcXVvdGU+PHNwYW4gY2xhc3M9IiI+IDxkaXYgY2xhc3M9InlncnBz LXlpdi04ODQ5NzUzNDRnbWFpbF9xdW90ZSI+T24gRnJpLCBPY3QgMTEsIDIwMTMgYXQgMTA6NDgg QU0sICA8c3BhbiBkaXI9Imx0ciI+Jmx0OzxhIHJlbD0ibm9mb2xsb3ciIHRhcmdldD0iX2JsYW5r IiBocmVmPSJtYWlsdG86Y2xpbWJhbGxkYXlALi4uIj5jbGltYmFsbGRheUAuLi48L2E+Jmd0Ozwv c3Bhbj4gd3JvdGU6PGJyPgo8YmxvY2txdW90ZSBjbGFzcz0ieWdycHMteWl2LTg4NDk3NTM0NGdt YWlsX3F1b3RlIiBzdHlsZT0ibWFyZ2luOjAgMCAwIC44ZXg7Ym9yZGVyLWxlZnQ6MXB4ICNjY2Mg c29saWQ7cGFkZGluZy1sZWZ0OjFleDsiPgoKCjx1PjwvdT4KCgoKCgoKCgoKCjxkaXYgc3R5bGU9 IiI+CjxzcGFuPiZuYnNwOzwvc3Bhbj4KCgo8ZGl2PgogIDxkaXY+CgoKICAgIDxkaXY+CiAgICAg IAogICAgICAKICAgICAgPHA+SGV5IGV2ZXJ5b25lLCA8YnI+PGJyPkkgZmluYWxseSBnb3QgZXZl cnl0aGluZyBpbiBwbGFjZSB5ZXN0ZXJkYXksIGFuZCBzZXQgdXAgYSB1c2VkLCBidXQgZXhjZWxs ZW50IGNvbmRpdGlvbiBBcnRpc2FuIDE0MzAgd2l0aCB0aGUgTUlTIEVib25pLTYgaW5rIHNldC4g VGhlIHF1YWxpdHkgb2YgdGhlIGltYWdlcyBzbyBmYXIgaXMgZ3JlYXQsIGJ1dCB3YXMgaGF2aW5n IHRyb3VibGUgd2l0aCBzb21lIGJsb3RjaGluZyBpbmsgb24gMyBvdXQgb2YgdGhlIDQgdGVzdCBw cmludHMgSSByYW4uIEkgdGhvdWdodCB0aGUgYmxvdGNoZXMgb2YgaW5rIHdvdWxkIGdvIGF3YXkg YWZ0ZXIgYSBjb3VwbGUgcnVucywgYW5kIHRoZSBzZWNvbmQgb25lIHdhcyBwZXJmZWN0LCBidXQg dGhlbiBpdCBnb3Qgd29yc2Ugd2l0aCB0aGUgbmV4dCB0d28sIHNvIEkgZGlkIGEgY2xlYW5pbmcs IGFuZCB0aGVuIGEgaGVhZCBjaGVjaywgdGhlbiByZXBlYXRlZCB0aGF0LCBhbmQgZm91bmQgdGhh dCBJIGFtIGdldHRpbmcgaW5jb25zaXN0ZW50IHJlc3VsdHMgZnJvbSB0aGUgaGVhZCBjaGVjayBw cmludHMuIDxicj4KPGJyPkkmIzM5O3ZlIG5vdyBkb25lIHRoZSBjbGVhbmluZyB0aHJvdWdoIHRo ZSBFcHNvbiBwcmludGVyIGRyaXZlIDQgdGltZXMsIGFuZCBkb25lIGEgY2hlY2sgZWFjaCB0aW1l LCBhbmQgZWFjaCB0aW1lIHRoZXJlIGFyZSBkaWZmZXJlbnQgcmVzdWx0cy4gTmV2ZXIgcGVyZmVj dCwgYnV0IGFsd2F5cyBhIGRpZmZlcmVudCBoZWFkIHRoYXQgaXNuJiMzOTt0IHF1aXRlIHJpZ2h0 LiA8YnI+Cjxicj5JIGtub3cgdGhhdCBoZWFkcyB3b3JrLCBhcyBJIHJhbiB0d28gdGVzdHMgd2l0 aCB0aGUgRXBzb24gaW5rIGJlZm9yZSBJIHB1cmNoYXNlZCB0aGUgbWFjaGluZSwgYW5kIGJvdGgg Y2FtZSBiYWNrIGZsYXdsZXNzLiBBZnRlciBicmluZ2luZyBpdCBob21lLCBJIHJhbiBhIGNvdXBs ZSBwcmludHMgd2l0aCB0aGUgb3JpZ2luYWwgaW5rLCBhbmQgdGhleSBsb29rZWQgZ29vZCBhcyB3 ZWxsLiBJdCYjMzk7cyBvbmx5IGFmdGVyIGluc3RhbGxpbmcgdGhlIE1JUyBjYXJ0cmlkZ2VzIHRo YXQgSSYjMzk7dmUgaGFkIHByb2JsZW1zLjxicj4KPGJyPldoZW4gc3RhcnRpbmcgdGhlIG5ldyBy ZWZpbGwgY2FydHJpZGdlcywgaWYgYW55dGhpbmcsIEkgdW5kZXJmaWxsZWQgdGhlIGNhcnRyaWRn ZXMsIGxlYXZpbmcgcm9vbSBhdCB0aGUgdG9wIChhYm91dCAxMGNjcywgd2hlbiB0aGV5IHdpbGwg dGFrZSB1cCB0byAxMiBvciAxMyBpdCBzZWVtcykuIEkgcmVwbGFjZWQgdGhlIGZpbGwgaG9sZSBw bHVncyB0aWdodGx5LCBidXQgcmVtb3ZlZCB0aGUgY2xlYXIgdmVudCBjYXBzLCBhcyBwZXIgdGhl IE1JUyBpbnN0cnVjdGlvbnMgb24gdGhlIDxhIHJlbD0ibm9mb2xsb3ciIHRhcmdldD0iX2JsYW5r IiBocmVmPSJodHRwOi8vaW5rc3VwcGx5LmNvbSI+aW5rc3VwcGx5LmNvbTwvYT4gd2Vic2l0ZS4g SSB1c2VkIGEga25pZmUgdG8gbGlnaHRseSBwdW5jdHVyZSB0aGUgcGxhc3RpYyBjb3ZlcmluZyB0 aGUgYm90dG9tIGhvbGUsIGJ1dCBsZWZ0IHRoZSBwbGFzdGljIGluIHBsYWNlLCBhbmQgZHJldyBl bm91Z2ggaW5rIG91dCBvZiB0aGUgYm90dG9tIHRvIGdldCBwYXN0IGFueSBhaXIgcG9ja2V0cy4g SSBhbHNvIGxldCB0aGUgcHJpbnRlciBzaXQgb3Zlcm5pZ2h0LCB3b25kZXJpbmcgaWYgbWF5YmUg dGhlIHByb2JsZW0gd2FzIGFpciBidWJibGVzLCBidXQgcGlja2VkIHVwIHRoZSBuZXh0IGRheSBl eGFjdGx5IHdoZXJlIEkgbGVmdCBvZmYsIHdpdGggdGhlIHNhbWUgcHJvYmxlbXMuIEkmIzM5O3Zl IGFsc28gdHJpZWQgcmVtb3ZpbmcgdGhlIGluayBjYXJ0cmlkZ2VzIGFuZCByZWluc3RhbGxpbmcg dGhlbS4gPGJyPgo8YnI+SSBjYW4ga2VlcCBydW5uaW5nIGNsZWFuaW5ncywgYnV0IEkgZG9uJiMz OTt0IHNlZW0gdG8gYmUgbWFraW5nIHByb2dyZXNzIHdpdGggdGhhdC4gSSYjMzk7bSBsb29raW5n IGZvciBvdGhlciBzdWdnZXN0aW9ucy4uLiA8YnI+PGJyPlRoYW5rcywgPGJyPjxicj5TdGVwaGVu PC9wPgoKICAgIDwvZGl2PgogICAgIAoKICAgIAogICAgPGRpdiBzdHlsZT0iY29sb3I6I2ZmZjtt aW4taGVpZ2h0OjA7Ij48L2Rpdj4KCgo8L2Rpdj4KCgoKICAKCgoKCgoKPC9kaXY+PC9kaXY+PC9i bG9ja3F1b3RlPjwvZGl2Pjxicj48L3NwYW4+PC9ibG9ja3F1b3RlPjwvZGl2Pgo8L2Rpdj4gICAg ICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgIDwvZGl2Pg==
Re: [Digital BW] RE: Artisan 1430 with Eboni-6 - Blotching and inconsistend print heads
If it's a cart problem contact MIS.
I have used MIS refillables for a long time with Eboni inks, and lots of others. The cart batch mine were from work very well, as have the MIS inks. All I really do is state what my experiences are.
On Fri, Oct 11, 2013 at 12:08 PM, <climballday@...> wrote:
Paul,
You may be right, but it seems to me that if that were the case, I'd have gotten indications with the test prints I ran with the original inks as well. I don't know the specifics of how the ink cartridges interface with the heads... I may try looking at that now, but I do feel that it's something to do with the MIS cartridges...
best,
Stephen
Hey everyone,
Stephen
2013-10-12 by <homershannon@...>
PHA+U3RlcGhhbjo8L3A+PHA+PGJyPjwvcD48cCBzdHlsZT0iY29sb3I6cmdiKDAsIDAsIDApO2Zv bnQtc2l6ZToxM3B4O2ZvbnQtZmFtaWx5OmFyaWFsLCBoZWx2ZXRpY2EsIGNsZWFuLCBzYW5zLXNl cmlmO2JhY2tncm91bmQtY29sb3I6dHJhbnNwYXJlbnQ7Zm9udC1zdHlsZTpub3JtYWw7Ij5JIGhh dmUgZXhhY3RseSB0aGUgc2FtZSBzZXQgdXAgYXMgeW91IC0gcmlnaHQgZG93biB0byB0aGUga25p ZmUgdG8gcHVuY3R1cmUgdGhlIHRhcGUgb24gdGhlIGJvdHRvbSBvZiB0aGUgY2FydHJpZGdlcyE8 L3A+PHAgc3R5bGU9ImNvbG9yOnJnYigwLCAwLCAwKTtmb250LXNpemU6MTNweDtmb250LWZhbWls eTphcmlhbCwgaGVsdmV0aWNhLCBjbGVhbiwgc2Fucy1zZXJpZjtiYWNrZ3JvdW5kLWNvbG9yOnRy YW5zcGFyZW50O2ZvbnQtc3R5bGU6bm9ybWFsOyI+PGJyPjwvcD48cCBzdHlsZT0iY29sb3I6cmdi KDAsIDAsIDApO2ZvbnQtc2l6ZToxM3B4O2ZvbnQtZmFtaWx5OmFyaWFsLCBoZWx2ZXRpY2EsIGNs ZWFuLCBzYW5zLXNlcmlmO2JhY2tncm91bmQtY29sb3I6dHJhbnNwYXJlbnQ7Zm9udC1zdHlsZTpu b3JtYWw7Ij5JIGFsc28gZ2V0IG9jY2FzaW9uYWwgZHJvcHMsIHdoaWNoIGlzIHdoYXQgSSB0aGlu ayB5b3UgYXJlIHJlZmVycmluZyB0byBhcyAmIzM5O2Jsb3RjaGVzJiMzOTssIGJ1dCBJJiMzOTt2 ZSBuZXZlciBmaWd1cmVkIG91dCBhIGN1cmUgYW5kIHRoZXkgb25seSBzZWVtIHRvIGhhcHBlbiBv biAxLzQtc2hlZXQgdGVzdCBwcmludHMuIFRoZXkmIzM5O3ZlIHJhcmVseSBydWluZWQgYSBsYXJn ZSBwcmludCBhbmQgSSBjYW4mIzM5O3QgZXhwbGFpbiB0aGVtLiBUaGUgY2xlYW5pbmcgb2YgdGhl IGJvdHRvbSBvZiB0aGUgaGVhZCBzb3VuZHMgbGlrZSBhIGdvb2QgaWRlYS4gQ29uZSBoYXMgdGhp cyB2aWRlbyB0aGF0IG1heSBiZSB1c2VmdWw6Jm5ic3A7PGEgcmVsPSJub2ZvbGxvdyIgdGFyZ2V0 PSJfYmxhbmsiIGhyZWY9Imh0dHA6Ly93d3cueW91dHViZS5jb20vd2F0Y2g/dj1lVXlzUUZESDZ1 MCIgc3R5bGU9ImxpbmUtaGVpZ2h0OjEuMjI7Ij5odHRwOi8vd3d3LnlvdXR1YmUuY29tL3dhdGNo P3Y9ZVV5c1FGREg2dTA8L2E+PHNwYW4gc3R5bGU9ImJhY2tncm91bmQtY29sb3I6dHJhbnNwYXJl bnQ7bGluZS1oZWlnaHQ6MS4yMjsiPiZuYnNwOy48L3NwYW4+PC9wPjxwIHN0eWxlPSJjb2xvcjpy Z2IoMCwgMCwgMCk7Zm9udC1zaXplOjEzcHg7Zm9udC1mYW1pbHk6YXJpYWwsIGhlbHZldGljYSwg Y2xlYW4sIHNhbnMtc2VyaWY7YmFja2dyb3VuZC1jb2xvcjp0cmFuc3BhcmVudDtmb250LXN0eWxl Om5vcm1hbDsiPjxzcGFuIHN0eWxlPSJiYWNrZ3JvdW5kLWNvbG9yOnRyYW5zcGFyZW50O2xpbmUt aGVpZ2h0OjEuMjI7Ij48YnI+PC9zcGFuPjwvcD48cCBzdHlsZT0iY29sb3I6cmdiKDAsIDAsIDAp O2ZvbnQtc2l6ZToxM3B4O2ZvbnQtZmFtaWx5OmFyaWFsLCBoZWx2ZXRpY2EsIGNsZWFuLCBzYW5z LXNlcmlmO2JhY2tncm91bmQtY29sb3I6dHJhbnNwYXJlbnQ7Zm9udC1zdHlsZTpub3JtYWw7Ij48 c3BhbiBzdHlsZT0iYmFja2dyb3VuZC1jb2xvcjp0cmFuc3BhcmVudDtsaW5lLWhlaWdodDoxLjIy OyI+UmVnYXJkaW5nIHlvdXIgcHJvYmxlbXMgd2l0aCB0aGUgaW5jb25zaXN0ZW50IG5venpsZSBj aGVja3MsIG1vc3QgbGlrZWx5IHRoZSBjdXJlIGlzIHRvIGRvIG1vcmUgcHVyZ2luZy4gSSByZWNl bnRseSB3ZW50IHRvIHRoZSBuZXctc3R5bGUgTUlTIGNhcnRyaWRnZXMgYW5kIEkgaGFkIGEgbG90 IG9mIHByb2JsZW1zIGluaXRpYWxseS4gQWZ0ZXIgc2V2ZXJhbCBleHRyYSBwdXJnZXMgLSBkcmF3 IG91dCBhdCBsZWFzdCA0bWwgYW5kIHJlLWZpbGwgLSB0aGUgcHJvYmxlbXMgc3RvcHBlZC4gVGhp cyB3YXMgY29uc2lzdGVudCBhY3Jvc3Mgc2V2ZXJhbCBjYXJ0cmlkZ2VzLiZuYnNwOzwvc3Bhbj48 L3A+PHAgc3R5bGU9ImNvbG9yOnJnYigwLCAwLCAwKTtmb250LXNpemU6MTNweDtmb250LWZhbWls eTphcmlhbCwgaGVsdmV0aWNhLCBjbGVhbiwgc2Fucy1zZXJpZjtiYWNrZ3JvdW5kLWNvbG9yOnRy YW5zcGFyZW50O2ZvbnQtc3R5bGU6bm9ybWFsOyI+PHNwYW4gc3R5bGU9ImJhY2tncm91bmQtY29s b3I6dHJhbnNwYXJlbnQ7bGluZS1oZWlnaHQ6MS4yMjsiPjxicj48L3NwYW4+PC9wPjxwIHN0eWxl PSJjb2xvcjpyZ2IoMCwgMCwgMCk7Zm9udC1zaXplOjEzcHg7Zm9udC1mYW1pbHk6YXJpYWwsIGhl bHZldGljYSwgY2xlYW4sIHNhbnMtc2VyaWY7YmFja2dyb3VuZC1jb2xvcjp0cmFuc3BhcmVudDtm b250LXN0eWxlOm5vcm1hbDsiPjxzcGFuIHN0eWxlPSJiYWNrZ3JvdW5kLWNvbG9yOnRyYW5zcGFy ZW50O2xpbmUtaGVpZ2h0OjEuMjI7Ij5Bbm90aGVyIHByb2JsZW0geW91ICZuYnNwO21heSBub3Qg aGF2ZSBydW4gaW50byB5ZXQsIGJ1dCBJJiMzOTt2ZSBoaXQgbWFueSB0aW1lcywgaXMgZmFsc2Ug bG93IGluayBjb25kaXRpb25zLiBJIG5ldmVyIGhhdmUgdGhpcyB3aXRoIHRoZSAxNDAwIGJ1dCB0 aGUgMTQzMCBkb2VzIGl0IGZyZXF1ZW50bHkuIFdoYXQgaGFwcGVucyBpcyB0aGF0IHRoZSBwcmlu dGVyIHN0b3BzIGFuZCBhIGNhcnRyaWRnZSB3aWxsIGhhdmUgdGhlIGxvdyBpbmsgbGlnaHQgb24u IFdoZW4geW91IGNoZWNrIHRoZSBjYXJ0cmlkZ2UsIGl0IHdvbiYjMzk7dCBiZSBvdXQgb2YgaW5r LiBSZW1vdmUgdGhlIGNhcnRyaWRnZSBhbmQgcm90YXRlIGFyb3VuZCB0aGUgdGhpbiBheGlzIHNs b3dseSBvbmNlIG9yIHR3aWNlIGFuZCBwdXQgaXQgYmFjayBpbiB0aGUgbWFjaGluZS4gVW5sZXNz IGFub3RoZXIgbG93IGluayBjb25kaXRpb24gcG9wcyB1cCwgd2hpY2ggc29tZXRpbWVzIGhhcHBl bnMsIHRoZSBwcmludGVyIHdpbGwgZ28gdGhyb3VnaCBhIGhlYWQgY2xlYW5pbmcgYW5kIHRoZW4g cmVzdW1lIHByaW50aW5nIHdpdGhvdXQgc28gbXVjaCBhcyBtaXNzaW5nIGEgc2luZ2xlIGxpbmUu IEkgZG9uJiMzOTt0IGtub3cgd2hhdCBjYXVzZXMgdGhpcy4gSXQgc2VlbXMgdG8gYmUgc29tZXRo aW5nIHdpdGggdGhlIHdheSB0aGUgY2FydHJpZGdlIGRyYWlucyBhbmQgaG93IHRoZSBzZW5zb3Jz IHRlbGwgaG93IGxvdyBpdCBpcy4gVGhpcyBoYXMgbm90IGNoYW5nZWQgb3ZlciB0aW1lLCBpdCBz dGlsbCBoYXBwZW5zIGFib3V0IGV2ZXJ5IDJuZCBvciAzcmQgdGltZSBJIHVzZSB0aGUgcHJpbnRl ci4mbmJzcDs8L3NwYW4+PC9wPjxwIHN0eWxlPSJjb2xvcjpyZ2IoMCwgMCwgMCk7Zm9udC1zaXpl OjEzcHg7Zm9udC1mYW1pbHk6YXJpYWwsIGhlbHZldGljYSwgY2xlYW4sIHNhbnMtc2VyaWY7YmFj a2dyb3VuZC1jb2xvcjp0cmFuc3BhcmVudDtmb250LXN0eWxlOm5vcm1hbDsiPjxzcGFuIHN0eWxl PSJiYWNrZ3JvdW5kLWNvbG9yOnRyYW5zcGFyZW50O2xpbmUtaGVpZ2h0OjEuMjI7Ij48YnI+PC9z cGFuPjwvcD48cCBzdHlsZT0iY29sb3I6cmdiKDAsIDAsIDApO2ZvbnQtc2l6ZToxM3B4O2ZvbnQt ZmFtaWx5OmFyaWFsLCBoZWx2ZXRpY2EsIGNsZWFuLCBzYW5zLXNlcmlmO2JhY2tncm91bmQtY29s b3I6dHJhbnNwYXJlbnQ7Zm9udC1zdHlsZTpub3JtYWw7Ij48c3BhbiBzdHlsZT0iYmFja2dyb3Vu ZC1jb2xvcjp0cmFuc3BhcmVudDtsaW5lLWhlaWdodDoxLjIyOyI+R29vZCBsdWNrITwvc3Bhbj48 L3A+PHAgc3R5bGU9ImNvbG9yOnJnYigwLCAwLCAwKTtmb250LXNpemU6MTNweDtmb250LWZhbWls eTphcmlhbCwgaGVsdmV0aWNhLCBjbGVhbiwgc2Fucy1zZXJpZjtiYWNrZ3JvdW5kLWNvbG9yOnRy YW5zcGFyZW50O2ZvbnQtc3R5bGU6bm9ybWFsOyI+PHNwYW4gc3R5bGU9ImJhY2tncm91bmQtY29s b3I6dHJhbnNwYXJlbnQ7bGluZS1oZWlnaHQ6MS4yMjsiPjxicj48L3NwYW4+PC9wPjxwIHN0eWxl PSJjb2xvcjpyZ2IoMCwgMCwgMCk7Zm9udC1zaXplOjEzcHg7Zm9udC1mYW1pbHk6YXJpYWwsIGhl bHZldGljYSwgY2xlYW4sIHNhbnMtc2VyaWY7YmFja2dyb3VuZC1jb2xvcjp0cmFuc3BhcmVudDtm b250LXN0eWxlOm5vcm1hbDsiPjxzcGFuIHN0eWxlPSJiYWNrZ3JvdW5kLWNvbG9yOnRyYW5zcGFy ZW50O2xpbmUtaGVpZ2h0OjEuMjI7Ij5Ib21lciBTaGFubm9uPC9zcGFuPjwvcD4gPGRpdiBjbGFz cz0ieWdyb3Vwcy1xdW90ZWQiPjxicj48YnI+LS0tSW4gZGlnaXRhbGJsYWNrYW5kd2hpdGV0aGVw cmludEB5YWhvb2dyb3Vwcy5jb20sICZsdDtyb2Fyay5wYXVsQC4uLiZndDsgd3JvdGU6PGJyPjxi cj48ZGl2IGlkPSJ5Z3Jwcy15aXYtMTc4MjA4NDkyMSI+PGRpdiBkaXI9Imx0ciI+SWYgaXQmIzM5 O3MgYSBjYXJ0IHByb2JsZW0gY29udGFjdCBNSVMuICZuYnNwOzxkaXY+PGJyPjwvZGl2PjxkaXY+ SSBoYXZlIHVzZWQgTUlTIHJlZmlsbGFibGVzIGZvciBhIGxvbmcgdGltZSB3aXRoIEVib25pIGlu a3MsIGFuZCBsb3RzIG9mIG90aGVycy4gJm5ic3A7VGhlIGNhcnQgYmF0Y2ggbWluZSB3ZXJlIGZy b20gd29yayB2ZXJ5IHdlbGwsIGFzIGhhdmUgdGhlIE1JUyBpbmtzLiAmbmJzcDtBbGwgSSByZWFs bHkgZG8gaXMgc3RhdGUgd2hhdCBteSBleHBlcmllbmNlcyBhcmUuICZuYnNwOzwvZGl2Pgo8ZGl2 Pjxicj48L2Rpdj48ZGl2PlBhdWw8L2Rpdj48L2Rpdj48ZGl2IGNsYXNzPSJ5Z3Jwcy15aXYtMTc4 MjA4NDkyMWdtYWlsX2V4dHJhIj48YnI+PGJyPjxibG9ja3F1b3RlPjxzcGFuIGNsYXNzPSIiPiA8 ZGl2IGNsYXNzPSJ5Z3Jwcy15aXYtMTc4MjA4NDkyMWdtYWlsX3F1b3RlIj5PbiBGcmksIE9jdCAx MSwgMjAxMyBhdCAxMjowOCBQTSwgIDxzcGFuIGRpcj0ibHRyIj4mbHQ7PGEgcmVsPSJub2ZvbGxv dyIgdGFyZ2V0PSJfYmxhbmsiIGhyZWY9Im1haWx0bzpjbGltYmFsbGRheUAuLi4iPmNsaW1iYWxs ZGF5QC4uLjwvYT4mZ3Q7PC9zcGFuPiB3cm90ZTo8YnI+CjxibG9ja3F1b3RlIGNsYXNzPSJ5Z3Jw cy15aXYtMTc4MjA4NDkyMWdtYWlsX3F1b3RlIiBzdHlsZT0ibWFyZ2luOjAgMCAwIC44ZXg7Ym9y ZGVyLWxlZnQ6MXB4ICNjY2Mgc29saWQ7cGFkZGluZy1sZWZ0OjFleDsiPgoKCjx1PjwvdT4KCgoK CgoKCgoKCjxkaXYgc3R5bGU9IiI+CjxzcGFuPiZuYnNwOzwvc3Bhbj4KCgo8ZGl2PgogIDxkaXY+ CgoKICAgIDxkaXY+CiAgICAgIAogICAgICAKICAgICAgPHA+UGF1bCwgPGJyPjxicj5Zb3UgbWF5 IGJlIHJpZ2h0LCBidXQgaXQgc2VlbXMgdG8gbWUgdGhhdCBpZiB0aGF0IHdlcmUgdGhlIGNhc2Us IEkmIzM5O2QgaGF2ZSBnb3R0ZW4gaW5kaWNhdGlvbnMgd2l0aCB0aGUgdGVzdCBwcmludHMgSSBy YW4gd2l0aCB0aGUgb3JpZ2luYWwgaW5rcyBhcyB3ZWxsLiBJIGRvbiYjMzk7dCBrbm93IHRoZSBz cGVjaWZpY3Mgb2YgaG93IHRoZSBpbmsgY2FydHJpZGdlcyBpbnRlcmZhY2Ugd2l0aCB0aGUgaGVh ZHMuLi4gSSBtYXkgdHJ5IGxvb2tpbmcgYXQgdGhhdCBub3csIGJ1dCBJIGRvIGZlZWwgdGhhdCBp dCYjMzk7cyBzb21ldGhpbmcgdG8gZG8gd2l0aCB0aGUgTUlTIGNhcnRyaWRnZXMuLi4gPGJyPgo8 YnI+YmVzdCwgPGJyPjxicj5TdGVwaGVuPGJyPjwvcD48cD4mbmJzcDs8L3A+IDxkaXY+PGJyPjxi cj4tLS1JbiA8YSByZWw9Im5vZm9sbG93IiB0YXJnZXQ9Il9ibGFuayIgaHJlZj0ibWFpbHRvOmRp Z2l0YWxibGFja2FuZHdoaXRldGhlcHJpbnRAeWFob29ncm91cHMuY29tIj5kaWdpdGFsYmxhY2th bmR3aGl0ZXRoZXByaW50QHlhaG9vZ3JvdXBzLmNvbTwvYT4sICZsdDtyb2Fyay5wYXVsQC4uLiZn dDsgd3JvdGU6PGJyPgo8YnI+PGRpdj48ZGl2IGRpcj0ibHRyIj5Gb3JlaWduIG9iamVjdHMgb24g dGhlIGJvdHRvbSBvZiB0aGUgaGVhZCBzb21ldGltZXMgZ2l2ZXMgbWUgcHJvYmxlbXMuICZuYnNw OyhJIHN1c3BlY3QgaXQmIzM5O3MgbW9zdGx5IGRvZyBoYWlyIGluIG15IGhvdXNlLCBhbmQgcmFy ZSBpbiBhbnkgY2FzZS4pICZuYnNwO1RoZSB3aXBlciBibGFkZSBkb2VzbiYjMzk7dCBhbHdheXMg ZG8gaXQmIzM5O3Mgam9iIG9mIHJlbW92aW5nIHRoZSBvZmZlbmRpbmcgc3R1ZmYuICZuYnNwO0kg dXNlIHNld2VycyYjMzk7IGJpYXMgdGFwZSBmcm9tIFdhbG1hcnQsIHNvYWtlZCB3aXRoIFdpbmRl eCwgdG8gZ2VudGx5IHB1bGwgYmFjayBhbmQgZm9ydGggYWNyb3NzIHRoZSBoZWFkIHRvIHJlbW92 ZSB3aGF0ZXZlciBpcyB0aGVyZS48YnI+Cgo8ZGl2Pjxicj48L2Rpdj48ZGl2PlBhdWw8L2Rpdj48 ZGl2PjxhIHJlbD0ibm9mb2xsb3ciIHRhcmdldD0iX2JsYW5rIiBocmVmPSJodHRwOi8vd3d3LlBh dWxSb2Fyay5jb20iPnd3dy5QYXVsUm9hcmsuY29tPC9hPiZuYnNwOzwvZGl2PjwvZGl2PjxkaXY+ PGJyPjxicj48YmxvY2txdW90ZT48c3Bhbj4gPGRpdj5PbiBGcmksIE9jdCAxMSwgMjAxMyBhdCAx MDo0OCBBTSwgIDxzcGFuIGRpcj0ibHRyIj4mbHQ7PGEgcmVsPSJub2ZvbGxvdyIgdGFyZ2V0PSJf YmxhbmsiIGhyZWY9Im1haWx0bzpjbGltYmFsbGRheUAuLi4iPmNsaW1iYWxsZGF5QC4uLjwvYT4m Z3Q7PC9zcGFuPiB3cm90ZTo8YnI+Cgo8YmxvY2txdW90ZSBzdHlsZT0iYm9yZGVyLWxlZnQ6MXB4 ICNjY2Mgc29saWQ7Ij4KCgo8dT48L3U+CgoKCgoKCgoKCgo8ZGl2Pgo8c3Bhbj4mbmJzcDs8L3Nw YW4+CgoKPGRpdj4KICA8ZGl2PgoKCiAgICA8ZGl2PgogICAgICAKICAgICAgCiAgICAgIDxwPkhl eSBldmVyeW9uZSwgPGJyPjxicj5JIGZpbmFsbHkgZ290IGV2ZXJ5dGhpbmcgaW4gcGxhY2UgeWVz dGVyZGF5LCBhbmQgc2V0IHVwIGEgdXNlZCwgYnV0IGV4Y2VsbGVudCBjb25kaXRpb24gQXJ0aXNh biAxNDMwIHdpdGggdGhlIE1JUyBFYm9uaS02IGluayBzZXQuIFRoZSBxdWFsaXR5IG9mIHRoZSBp bWFnZXMgc28gZmFyIGlzIGdyZWF0LCBidXQgd2FzIGhhdmluZyB0cm91YmxlIHdpdGggc29tZSBi bG90Y2hpbmcgaW5rIG9uIDMgb3V0IG9mIHRoZSA0IHRlc3QgcHJpbnRzIEkgcmFuLiBJIHRob3Vn aHQgdGhlIGJsb3RjaGVzIG9mIGluayB3b3VsZCBnbyBhd2F5IGFmdGVyIGEgY291cGxlIHJ1bnMs IGFuZCB0aGUgc2Vjb25kIG9uZSB3YXMgcGVyZmVjdCwgYnV0IHRoZW4gaXQgZ290IHdvcnNlIHdp dGggdGhlIG5leHQgdHdvLCBzbyBJIGRpZCBhIGNsZWFuaW5nLCBhbmQgdGhlbiBhIGhlYWQgY2hl Y2ssIHRoZW4gcmVwZWF0ZWQgdGhhdCwgYW5kIGZvdW5kIHRoYXQgSSBhbSBnZXR0aW5nIGluY29u c2lzdGVudCByZXN1bHRzIGZyb20gdGhlIGhlYWQgY2hlY2sgcHJpbnRzLiA8YnI+Cgo8YnI+SSYj Mzk7dmUgbm93IGRvbmUgdGhlIGNsZWFuaW5nIHRocm91Z2ggdGhlIEVwc29uIHByaW50ZXIgZHJp dmUgNCB0aW1lcywgYW5kIGRvbmUgYSBjaGVjayBlYWNoIHRpbWUsIGFuZCBlYWNoIHRpbWUgdGhl cmUgYXJlIGRpZmZlcmVudCByZXN1bHRzLiBOZXZlciBwZXJmZWN0LCBidXQgYWx3YXlzIGEgZGlm ZmVyZW50IGhlYWQgdGhhdCBpc24mIzM5O3QgcXVpdGUgcmlnaHQuIDxicj4KCjxicj5JIGtub3cg dGhhdCBoZWFkcyB3b3JrLCBhcyBJIHJhbiB0d28gdGVzdHMgd2l0aCB0aGUgRXBzb24gaW5rIGJl Zm9yZSBJIHB1cmNoYXNlZCB0aGUgbWFjaGluZSwgYW5kIGJvdGggY2FtZSBiYWNrIGZsYXdsZXNz LiBBZnRlciBicmluZ2luZyBpdCBob21lLCBJIHJhbiBhIGNvdXBsZSBwcmludHMgd2l0aCB0aGUg b3JpZ2luYWwgaW5rLCBhbmQgdGhleSBsb29rZWQgZ29vZCBhcyB3ZWxsLiBJdCYjMzk7cyBvbmx5 IGFmdGVyIGluc3RhbGxpbmcgdGhlIE1JUyBjYXJ0cmlkZ2VzIHRoYXQgSSYjMzk7dmUgaGFkIHBy b2JsZW1zLjxicj4KCjxicj5XaGVuIHN0YXJ0aW5nIHRoZSBuZXcgcmVmaWxsIGNhcnRyaWRnZXMs IGlmIGFueXRoaW5nLCBJIHVuZGVyZmlsbGVkIHRoZSBjYXJ0cmlkZ2VzLCBsZWF2aW5nIHJvb20g YXQgdGhlIHRvcCAoYWJvdXQgMTBjY3MsIHdoZW4gdGhleSB3aWxsIHRha2UgdXAgdG8gMTIgb3Ig MTMgaXQgc2VlbXMpLiBJIHJlcGxhY2VkIHRoZSBmaWxsIGhvbGUgcGx1Z3MgdGlnaHRseSwgYnV0 IHJlbW92ZWQgdGhlIGNsZWFyIHZlbnQgY2FwcywgYXMgcGVyIHRoZSBNSVMgaW5zdHJ1Y3Rpb25z IG9uIHRoZSA8YSByZWw9Im5vZm9sbG93IiB0YXJnZXQ9Il9ibGFuayIgaHJlZj0iaHR0cDovL2lu a3N1cHBseS5jb20iPmlua3N1cHBseS5jb208L2E+IHdlYnNpdGUuIEkgdXNlZCBhIGtuaWZlIHRv IGxpZ2h0bHkgcHVuY3R1cmUgdGhlIHBsYXN0aWMgY292ZXJpbmcgdGhlIGJvdHRvbSBob2xlLCBi dXQgbGVmdCB0aGUgcGxhc3RpYyBpbiBwbGFjZSwgYW5kIGRyZXcgZW5vdWdoIGluayBvdXQgb2Yg dGhlIGJvdHRvbSB0byBnZXQgcGFzdCBhbnkgYWlyIHBvY2tldHMuIEkgYWxzbyBsZXQgdGhlIHBy aW50ZXIgc2l0IG92ZXJuaWdodCwgd29uZGVyaW5nIGlmIG1heWJlIHRoZSBwcm9ibGVtIHdhcyBh aXIgYnViYmxlcywgYnV0IHBpY2tlZCB1cCB0aGUgbmV4dCBkYXkgZXhhY3RseSB3aGVyZSBJIGxl ZnQgb2ZmLCB3aXRoIHRoZSBzYW1lIHByb2JsZW1zLiBJJiMzOTt2ZSBhbHNvIHRyaWVkIHJlbW92 aW5nIHRoZSBpbmsgY2FydHJpZGdlcyBhbmQgcmVpbnN0YWxsaW5nIHRoZW0uIDxicj4KCjxicj5J IGNhbiBrZWVwIHJ1bm5pbmcgY2xlYW5pbmdzLCBidXQgSSBkb24mIzM5O3Qgc2VlbSB0byBiZSBt YWtpbmcgcHJvZ3Jlc3Mgd2l0aCB0aGF0LiBJJiMzOTttIGxvb2tpbmcgZm9yIG90aGVyIHN1Z2dl c3Rpb25zLi4uIDxicj48YnI+VGhhbmtzLCA8YnI+PGJyPlN0ZXBoZW48L3A+CgogICAgPC9kaXY+ CiAgICAgCgogICAgCiAgICA8ZGl2IHN0eWxlPSJjb2xvcjojZmZmOyI+PC9kaXY+CgoKPC9kaXY+ CgoKCiAgCgoKCgoKCjwvZGl2PjwvZGl2PjwvYmxvY2txdW90ZT48L2Rpdj48YnI+PC9zcGFuPjwv YmxvY2txdW90ZT48L2Rpdj4KPC9kaXY+ICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAg ICAgICAgICAgICAgICAgICA8L2Rpdj4KCiAgICA8L2Rpdj4KICAgICAKCiAgICAKICAgIDxkaXYg c3R5bGU9ImNvbG9yOiNmZmY7bWluLWhlaWdodDowOyI+PC9kaXY+CgoKPC9kaXY+CgoKCiAgCgoK CgoKCjwvZGl2PjwvZGl2PjwvYmxvY2txdW90ZT48L2Rpdj48YnI+PC9zcGFuPjwvYmxvY2txdW90 ZT48L2Rpdj4KPC9kaXY+ICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAg ICAgICAgICA8L2Rpdj4=
