ConeColor for 1400
ConeColor for 1400
2013-10-26 by <benedictchen22@...>
Hi guys I'm expanding to include color into my work. planing on a second 1400 for cone pigment set is it any good is it any different from the other options in the market?
RE: ConeColor for 1400
2013-10-26 by <kjrslr@...>
I have a pair of 4800's and have one set up with a custom color Cone ink set and the other with a split tone piezography(B&W) ink set. As far as the color goes, since mine is a custom set(the LK & LLK are piezography selenium inks) I had to make up my own profiles but from what I've read, you can slide the Conecolor in place of the Epson OEM inks without any problem.
---In digitalblackandwhitetheprint@yahoogroups.com, <benedictchen22@...> wrote:
Re: [Digital BW] ConeColor for 1400
2013-10-27 by William Harvey
I have been using Cone pigments (K3) in a 1400 for more than two years.
They work all the time every time and I am very pleased with this
inkset. The "canned" profiles that are supplied with the inks are right
on!!!. I had some "custom" profiles made and just by way of seeing how
close the Cone profiles were I printed an image using both profiles on
the same paper and was amazed at how much better the Cone profile was.
The color fidelity was plainly better, shadow color detail was better,
instead of the shadows sinking into a dark monochrome they were alive
with the colors I was seeing on my monitor.
I have used MIS pigments and for my money there is no comparison, the
Cone Color inks are an order of magnitude better in all respects.
It is important to get the carts that Cone sells for the 1400 they work
great, I had used some other carts and they caused me nothing but
trouble to the point that I was considering abandoning the 1400 but I
switched to the Cone carts and they hit the ground running and I have
not looked back since!
A note about auto re-setting carts. When I run low on an individual ink
in this printer I refill all of the carts and use a chip re-setter (also
sold by Cone) to reset all of the chips at the same time. In this way
there is just *one*  cleaning cycle (using expensive inks to clean the
print head) when I am finished refilling the carts.
Hope this helps
Cheers
Default-WH
William Harvey
Mas de Cazes
Parisot 82160
France
05-63-24-19-36
+33 5 63-24-19-36
Lat. = 44 degrees, 15.1 minutes North
Long. = 1 degrees, 50.6 minutes East
2013-11-22 by <homershannon@...>
You might want to also check out Cone's new dye ink; Inkthrift CL. Cone claims it is as archival as Epson Claria which, if you look at the test scores on Aardenberg Imaging, is very good. I have not used pigment inks in my 1400 or 1430 but I have heard that they tend to clog more. Also, I have seen prints using Cone pigment and compared to dye inks it really loses punch. I believe this is pretty much true of all pigment inks compared do dye inks. For my tastes, I'd stay with dye.
I've been using MIS dye inks, which are 1/40 the price of Epson Claria. For prints I sell or need to be archival, I use Epson Claria. When my supply of Epson ink runs out I'll be moving to the Cone CL, which is three times more expensive than MIS but still 1/17 the price of Epson Claria!
---In DigitalBlackandWhiteThePrint@yahoogroups.com, <benedictchen22@...> wrote:
2013-11-22 by Leslie Tihor
I've been using Cone's pigment inks for a few months in my Epson 3800. I can see no difference in any way, including tendency to clog, from Epson's OEM inks. They are not as vivid as Cone's InkThrift inks, which I have also tried. But they are certainly a match for Epson's pigment inks at a small fraction of the cost.
Les
