Banding at start and end of the print - Epson 1430 + Eboni inks
2014-07-19 by climballday@...
Like the subject line says, I've started getting severe banding at the leading and tailing edges of my prints. Everything through the middle is fine, but 1/2" to 1" on the front and trailing edge act like the printer is skipping lines or something.
Epson Artisan 1430 printer
Eboni 6 inks with cartridges from MIS.
It happens on both Moab Arches 300 and hahnemuhle bamboo papers (the only two I have tested since it started)
Settings are at 2880 and uni-directional, which have always worked well for me, until now.
the nozzle test print looks fine.
I can do more experimenting, but in searching this group, I saw a message from Paul from several years ago that said something to the effect of "except at the leading edge of the print, there is no reason you should get banding" which made me think this might be some sort of a known issue. Unfortunately, further searching didn't turn up any messages referring to it specifically.
So... is this something that happens consistently under certain circumstances? If so, what's the solution to eliminating it?
Thanks to everyone... this group has been invaluable as I've started off on this little adventure.
Stephen
