Eb6 in 1400 Yellow Position printing too dark
2015-08-25 by Bharat Patel
Yesterday I refilled only the Magenta and Cyan cartridges on my 1400 using Eb6 and then also checked inks in all other cartridges one by one.
Now when I print, the yellow position prints too dark - almost like K ink which sits next to it! Easily seen by printing in Calibration Mode on QTR. What could be going wrong? Anyone had similar experience with 1400? Solution?
ThanksBharat
Re: [Digital BW] Eb6 in 1400 Yellow Position printing too dark
2015-08-25 by Jacques Caron
Hi, I,m on a 1430 but it looks very close to a 1400
Here's my two cents :
1-if you print a nozzle check, the "Yellow" pattern is almost black
2- You print a second one and the pattern shows less black lines.
It happened to me after refilling; I would check the wiper blade and clean the heads. There is a nice video about it from ink Jet Mall.
Good luck
Jacques Caron
Photographe
jacques.caron@...
Le 2015-08-25 à 05:15, "Bharat Patel yoursnaps@... [DigitalBlackandWhiteThePrint]" <DigitalBlackandWhiteThePrint@yahoogroups.com> a écrit :
> Hi,
> Thanks
> Bharat
2015-08-25 by Paul Roark
I've seen what might be called "cross-channel pollution" occasionally in nozzle checks, but it seems to clear with a cleaning or purge pattern print. I'm not sure how the ink physically gets into the wrong place. It might be leakage from the K cart that gets sucked into the Yellow cart-printer coupling or gets their via capillary action.
On Tue, Aug 25, 2015 at 2:15 AM, Bharat Patel yoursnaps@... [DigitalBlackandWhiteThePrint] <DigitalBlackandWhiteThePrint@yahoogroups.com> wrote:
Thanks
Bharat
Among other things I ended up doing a head clean! That seems to have sorted the problem. I will probably have to do a proper clean at some point soon. But how/why the ink gets sucked into other passages is baffling!
Bharatwww.bharatpatelphotography.co.uk
       From: "Paul Roark roark.paul@... [DigitalBlackandWhiteThePrint]" <DigitalBlackandWhiteThePrint@yahoogroups.com>
 To: DigitalB&WPrint <DigitalBlackandWhiteThePrint@yahoogroups.com>
 Sent: Tuesday, August 25, 2015 4:15 PM
 Subject: Re: [Digital BW] Eb6 in 1400 Yellow Position printing too dark
Paulwww.PaulRoark.com
On Tue, Aug 25, 2015 at 2:15 AM, Bharat Patel yoursnaps@... [DigitalBlackandWhiteThePrint] <DigitalBlackandWhiteThePrint@...m> wrote:
ThanksBharat
2015-08-26 by brian_downunda@...
You may find that printing a purge pattern is another way to clear cross-channel contamination, which uses less ink. If you're printing using QTR it is possible to target just that channel that exhibits this problem. IJM have a page on their support site that details how to do just that, including the necessary files. In my view head cleans are for clogs and purge patterns are for everything else, at least as a first line of attack.
p.s. If you find cross-channel contamination on a reasonably regular basis, it is a sign of something. Perhaps incorrect cartridge filling technique, or slowly leaking carts, or a printer that needs the usual cleaning routine, or an older printer than is struggling with refillables.
Re: Eb6 in 1400 Yellow Position printing too dark
2015-08-26 by ascherjim@...
As the Yellow position (my 6% dilution) is physically right next to the K position (100% ink), is not this close physical proximity part of the problem?  What would happen if, through my QTR printing set-up I change the physical positions of the various ink dilution percentages, i.e., with, say, the 30% dilution (instead of the 6%) next to the 100% ink.  Would this possibly lessen the likelihood of such ink "leaking?"   In doing this, I would of course modify my QTR printing profile accordingly, to reflect this change of ink positions.
2015-08-27 by brian_downunda@...
I can't see that it's going to address the cause of the problem. It may make it less obvious. Personally I'd want to know, and the more obvious it is, the easier it is to know.
