[Digital BW] Re: (Paul)Why do mac and pc use different curves?
2002-03-15 by Paul Roark
Jim,
You wrote:
>...Why would a
>Spectrophotometer be better than a densitometer to tweak your curves
>when reading a test step wedge directly off a printer?
As best I can tell, "densitometer" is just the unofficial term used for what
the manufacturers call "spectrophotometers."
I make the assumption that these devices are better at reading color and
density -- their reasons for being -- than the affordable desktop scanner I
and I think most of us use.
What I actually find is that the densitometer allows me to calibrate my
Epson 1600 scanner gamma.  This is not a trivial problem.  And, I think that
one thing that might real help is if I make calibrated test strips available
to those I work with who are doing scanning of test strips.
Once the gamma is set, the scanner then makes a good way to quickly read the
grayscale densities and have the results in percentages.
However, my scanner's color readings are off and not very linear, according
to the X-rite. And, judging from what I saw in the many scans from others,
there is quite a bit of variance among scanners.  So, I'm now using the
densitometer to read the colors, which was most important to get a really
neutral curve with the VM-sepia.
Actually, I'm now balancing out the old 3000-PC "cold" curve to be a sepia
"brown" curve (one step back from full-on sepia -- maybe I ought to call it
"very warm").  I'm finding that visual eyeballing of the test strip is as
good as anything for the color of this curve.
>I have a friend who has a computerized way of generating curve data,
>but uses a densitometer. I was arguing that it might not get all the
>color tones right, esp with VM.?
I don't know.  There are expensive spectrophotometers/densitometers that do
automate the reading, at least.  However, they are big bucks.  (A DPT22 like
I have has recently sold on EBay for about $300.)
Re: [Digital BW] Re: (Paul)Why do mac and pc use different curves?
2002-03-15 by Don Rooney
Hi Paul and Jim
As I can't copy and paste (not sure of legality) the following info is available at the XRITE website. It gives definitions of the various types of meters. If you want I will try to get my XRITE rep to respond. But in the mean time read this. Also -- they have a PDF 12 pages long that talks about densitometry -- but you have to be wearing your beanie with the propeller attached <g> as it is pretty technical
http://www.xrite.com/documents/mktg/L7-093DensGuide.pdf
don
  To: DigitalB&WPrint
  Sent: Friday, March 15, 2002 9:05 AM
  Subject: [Digital BW] Re: (Paul)Why do mac and pc use different curves?
  Jim,
  You wrote:
  >...Why would a
