How much ink in tubes?
2002-03-19 by tomoc
Well... I got my pints of FSN today. Switched out the FS inks and ran
about 5 MIS purge files and started printing.
Anybody know if this was enough to get all the old ink flushed
through the CIS system?
I thought I had read that was enough, but if it is, I'm hard pressed
to see the difference between FS and FSN (lovely though it is).
Tom O'Connell
TomOC@...
www.thomasoconnell.com
Re: How much ink in tubes?
2002-03-19 by johnvphoto
> Tom O'Connell
Tom,
I recently replaced Generations 3 yellow with Generations 4
yellow in my CIS. I made a 7"x9" purge patch in Illustrator. It took
about 55 sheets to totally replace the old yellow with the new - I
used my flat bed scanner to measure the color value change.
Start purging!
Best,
John V.
RE: [Digital BW] Re: How much ink in tubes?
2002-03-19 by Barry Kelsall
Why buy pints of ink, but not new carts? It's not that hard to do, or that
expensive to replace the carts in a CIS. And you start out fresh with the
new ink. You may never clean out all the old ink in the carts. Why use a
contaminated workflow?
I also went from Gen 3 to Gen 4 some time ago. As I recall, it took less
than 30 min to replace the carts & only 2 days for the stains to wash off my
fingers. :)
It took just one purge sheet to clean the old ink out of the heads.
If it matters, I did this on an 1160. -BK
> From: johnvphoto [mailto:johnnyv@...]
> Sent: Tuesday, March 19, 2002 4:56 AM
> Subject: [Digital BW] Re: How much ink in tubes?
> > Tom O'Connell
> Tom,
> Start purging!
> Best,
> John V.
> Please visit the Group Homepage to check the Files, Bookmarks,
> Polls and other resources as they are often being updated. The page is at:
> - As threads develop, trim off excess portions of earlier
> messages to keep them short.
> - Good manners are required at all time. No personal attacks or "flames."
> - Before posting a question, search the message archives and the
> various resources on the homepage.
2002-03-19 by tomoc
thanks... Good thing I bought the 16 oz. not the 4 oz. <vbg>
Tom O'Connell
TomOC@...
--- In DigitalBlackandWhiteThePrint@y..., "johnvphoto" <johnnyv@c...>
> > Tom O'Connell
> Tom,
took
> Start purging!
> Best,
> John V.
Re:How much ink in tubes?
2002-03-21 by Jon Zax
When I switched over an Inkset in my CIS system I got in touch with
NoMoreCarts  for their
recommendations.
They said the ink in the cart was the problem, not the tubes, because
the carts have sponges in them
and that the old ink, in effect, never goes away.
They sell (through their agents) replacement carts very inexpensively
and say that is the way it should be done.
My caveat is, make sure you keep track of which tank each tube runs to.
I didn't and had to do the
whole thing over again. On a 5 tank cart I got only one tube on the
right position.
J.Z.
