Scanning old postcard for use on book cover
2002-05-03 by David J. Bookbinder
NOTE: I'm cross-posting to the DigitalBlackandWhite and the Scan lists. A friend of mine has asked me to scan an old postcard she will be using on a book cover. The postcard is in black and white, on time-yellowed stock. It will be positioned at a roughly 30% angle from horizontal on the book cover. The service bureau wants a 300dpi TIFF file, and they are using a 150 line screen. I'm wondering: 1. Do I need to take into account the dot pattern of the postcard somehow, and if so, how? 2. Am I better off scanning the postcard at the approximate angle at which it will be printed, or rotating it in photoshop? 3. Am I better off trying to adjust for the yellowing in the scanning process, or do that later in Photoshop? And, if the latter, am I better off scanning in RGB so I can selectively remove or lighten the color before turning the image into black and white? 4. How much sharpening should I apply to this image before I hand it back to my friend? I normally output to inkjet printers, and they seem to require almost no sharpening, but everything I've read indicates this is not the case with press work. Sorry if these are obvious questions, but this is not normally what I do with images, so it's something of a mystery to me. TIA - More anon, - David David J. Bookbinder [david_bookbinder@...]
