[Digital BW] Best file output dpi for 860/1160?
2002-05-12 by Paul Roark
>...what is the sweet spot for file dpi to >output for BW to a 4-color printer . . what are people using. ... I scan at 4000 dpi and just leave it there. It ends up above 360 and less than 720. I've done tests and found that the driver can use information above 360. I think I've read 720 is the limit. As a practical matter, however, the difference between 360 and 720 is barely detectable -- with either Epson or Cone drivers. The highest resolution (optical line pairs per mm) I've ever seen with them is about 9 lp/mm. At 360 you can hit about 7 lp/mm with both. Above 5 lp/mm the main visual difference in any system is probably edge acutance, which can't really be measured by my lp/mm testing. When viewing actual enlargements and weighing file size, I concluded that 360 was the highest I needed. Paul http://www.PaulRoark.com
