[Digital BW] Re: New Set of MIS VM Curves for 1270 & 870
2002-05-22 by Paul Roark
Shilesh,
>I did rough density measurents (scanner based) on Epson color dyes
>and the FS Quads, and I believe the FS inks loaded in the following
>order will require very small curves adjustments (I will try them in
>a couple of days):
>CcMmYK (inks positions) = CYCYMK (FS inks) or Dark, Light, Dark,
>Light, Medium, Black. This is slightly different from my current ink
>positions of CcMmYK = CMCMYK.
I would think the C to Y difference might be a bit on the large side.  Did
you ever try the C & M system with M also in the yellow position?  With all
3 jets firing M in the highlights I was guessing that it might be too dark.
At any rate, I'll be curious what you find with the new ink positions.
http://www.PaulRoark.com
_________________________
--- In DigitalBlackandWhiteThePrint@y..., "Paul Roark"
<paul.roark@v...> wrote:
> Hi,
> For 1270 and 870 owners, a new set of Photoshop image adjustment
curves has
> been posted in the Files section of this forum.  The Files section
is at:
> From there go to:  > Ink Sets, reviews and techniques > MIS
Variable Mix >
> 870 and 1270 Curves
> Martin has put all the curves in a Zip file that also includes a
text file
> with the setting information.
> These curves use different settings than the older 1270 curves.
The first
> difference is that the Epson driver color management setting
is, "No Color
> Adjustment."  So the sliders are disabled.  But, the trade-off is
that the
> curves should be cross-platform. (The names have a prominent "NCA"
in them
> to remind me and others of this change.)
> I wrote the curves on an 870-PC platform.  So, I'd be most curious
how they
> work on a 1270-Mac platform.
> These curves also use paper-type setting of Matte Heavy Weight, not
> Quality Ink Jet.  The curves, as usual, were written for Epson
> Archival/Enhanced Matte.
> The curves also are written for Adobe RGB (1998) working space.  (I
set the
> Color Settings (under "Edit") first to PS 5 defaults and then just
change
> the RGB working space to Adobe RGB (1998).)
> I've re-named the "mw" curve the "nw" curve.  When this curve is
used with
> EAM, the print is initially dead neutral in the mid-ranges --
according to
> the X-Rite densitometer I used to write the curves.  (Of course,
the paper
> tone affects the highlights, and the warm black affects the deep
shadows.)
> So, the "nw" curve starts neutral but will warm to medium warm.
> Note also that one of the curves is a grayscale printing curve.
There is no
> RGB mode conversion in the workflow for this curve.  Just apply the
curve
> and print.  (Be careful not to save an altered file, which will not
be as
> obvious as in the RGB workflows.)  The print is 0.01 unit cool in
> lighter tones and a bit cooler in the shadows, with a maximum 0.03
cool at
> 65-70%.  (These modern, hextone Epsons clearly do not need
partitioning
> curves to get smooth highlights.)
> Let me know how these new curves work on your 1270s.
> Paul
Global Curves Was New Set of MIS VM Curves for 1270 & 870
2002-05-22 by janishilesh
Paul,
I never tried your alternate inks position suggestion - I was too
busy printing photographs as opposed to test strips (finally!) to
mess with the work flow. But the engineer in me is always looking for
a good experiment, so I will give it a go. The guys at LincolnInks
have been suggesting a tri-tone solution without partitioning for
quite a while now, and that may well be the way to go!
Shilesh
> Shilesh,
in
> >a couple of days):
ink
side.  Did
With all
too dark.
positions.
> Paul
> > Hi,
> curves has
> is at:
> Variable Mix >
> > 870 and 1270 Curves
> text file
> The first
> is, "No Color
> that the
> in them
> how they
not
> Photo
(I
> set the
> change
> used with
> according to
> the paper
> shadows.)
> There is no
> curve
not
> be as
> the
> cool at
> partitioning
> > Paul
Re: [Digital BW] Re: New Set of MIS VM Curves for 1270 & 870
2002-05-22 by Editor P.O.V. Image Service
On my 1270, the new curves give me significantly better transitions in
the darker tonalities...  It is apparent on large expanses of
 darkeneing skies (one example).
THANKS FOR ALL THE HARD WORK PAUL!!!
[Keith]
2002-05-23 by Paul Roark
Keith,
Do you use a Mac or PC?
[Keith]
2002-05-23 by ednmetrodc
--- In DigitalBlackandWhiteThePrint@y..., "Editor P.O.V. Image Service" <editor@p...>
wrote:
I'm on a Mac with an 870 and the new curves are definitely better than the old ones
(ver. 6). All curves are much smoother, especially in the 70-100% range. I would say
that the cool curve is perfect; the neutral curve is almost perfect, but it has a small
bit of banding at about the 70-75% tone; the nw curve has a little bump around the
45%, and another around 75-80%, and still another around 85-90%; and the warm
curve is a little worse (but still much better than the old curve), especially around
45%, 70-75%, and 80-85%.
Overall the curves are smoother, the color is relatively evenly spaced from cool to
warm, and the separation, particularly in the 90-100% range is more even than
before. Tyler's Zees look better... now I can see the next to last darkest Z against its
background.
Paul, thank you!
Ed
