Re: [Digital BW] 8 bit to 16-Canon G2 is 16 bit
2002-05-27 by Truman Prevatt
Speaking of Canon, I converted some raw files in 16 bit linear (gamma=1)
the other day. I then went to change the gamma in Photoshop 7. I
couldn't for the life of me find where theyh put the gamma adjustment.
Used to be in image>adjustment>gamma. That's where the online help says
it is. It's not even covered in the paper manual. I'm sure it used to be
there in version 6. Am I going nuts or did they hind it someplace just
to keep me confused - not hard to do these days.
Thanks
Truman
jimhayes361 wrote:
> --- In DigitalBlackandWhiteThePrint@y..., "tomoc" <TomOC@s...> wrote:
> > Hi all-
> > I thought Austin was going to address this in the last 16/8 thread,
> > but it died <g>.
> > Do you think there is any advantage gained from converting an 8 bit
> > image (usually a .jpg from a Nikon 5000) to 16 bit before doing any
> > adjustments in PS?.
> I'm only going to comment on the digital camera part. Without starting
> a Nikon/Canon war, if you have a Canon G2 instead of the Nikon 5000,
> it passes 10 bits to photoshop in "16 bit mode", allowing you to edit
> images easily. The G2 is in the same price range and feature set as
> the Nikon 5000, with the Nikon at 5 megapixels vs 4 for the Canon,
> which I don't feel makes a lot of difference, but the Canon has a
> faster lens at f2 vs f2.8, which I feel does make a quality
> difference.
> In this light, there is no need to worry about not having headroom to
> work the curves.
> Also when storing a full RAW image, Canon only uses about 3.5 mb on
> the CF card- it stores the color info encoded in some way, so that
> software is used to process the full color image once back home on
> your computer.
> Jim H.
