Re: [Digital BW] Re: Native resolution for scanning
2002-06-06 by daschkenas@aol.com
Austin, A friend just purchased an epson 2450. After your advice concerning the native resolution for scanning with a Umax MirageII, which was right on, do you happen to know what the native resolution for the epson would be? Thanks again David Aschkenas
2002-06-06 by Austin Franklin
Hi David, Easy enough to find... http://www.epson.com click on "Canada/United States" click on "Scanners" click on "Perfection 2450 PHOTO Scanner" And you can either read what they say there, or get even more information by downloading the .pdf spec sheet....or click on "See Detailed List..." ;-)
> -----Original Message----- > From: daschkenas@... [mailto:daschkenas@...] > Sent: Thursday, June 06, 2002 4:27 PM > To: DigitalBlackandWhiteThePrint@yahoogroups.com > Subject: Re: [Digital BW] Re: Native resolution for scanning > > > Austin, A friend just purchased an epson 2450. After your advice > concerning the native resolution for scanning with a Umax > MirageII, which was right on, do you happen to know what the > native resolution for the epson would be? > Thanks again > David Aschkenas
2002-06-07 by daschkenas@aol.com
Austin, I checked out the info on the epson site about the 2450, and read that the resolution is 2400, but no mention of NATIVE RESOLUTION, Is the answer to the question 2400? David
2002-06-07 by Peter Marquis-Kyle
> Austin, I checked out the info on the epson site about the 2450, and read that the resolution is 2400, but no mention of NATIVE RESOLUTION, Is the answer to the question 2400? > David I'm not Austin, but I'll speak up. Yes, you got the right answer. Think of native resolution as the highest resolution the scanner can do without interpolation (where new pixels are 'created' by the software). The Epson 2450 can scan at 2400 x 4800 samples per inch. Imagine a row of sensors spaced at 1/2400 inch, which steps across the original at 1/4800 inch intervals. But your image editing program (Photoshop or whatever) can't deal with pixels that are not on a square grid. To use the 2400 x 4800 scan the scanner software has to interpolate to 4800 x 4800, by 'inventing' the missing pixels by averaging the neighbouring pixels. If you tell the scanner to sample at 2400 x 2400 the sensors step across the original at 1/2400 inch intervals, and every pixel is 'real'. Native resolution. Peter Marquis-Kyle
2002-06-07 by Austin Franklin
> Austin, I checked out the info on the epson site about the 2450, > and read that the resolution is 2400, but no mention of NATIVE > RESOLUTION, Is the answer to the question 2400? > David Hi David, On the page linked to by "See Detailed List >>" it says: "Optical Resolution 2400 dpi" which is the same as "native" resolution. So, yes, the answer is 2400. Regards, Austin
2002-06-07 by William Cobb
BTW => Native resolution = OPTICAL resolution
-----Original Message----- From: Peter Marquis-Kyle [mailto:petermk@...] Sent: Thursday, June 06, 2002 7:04 PM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: Re: [Digital BW] Re: Native resolution for scanning > Austin, I checked out the info on the epson site about the 2450, and read that the resolution is 2400, but no mention of NATIVE RESOLUTION, Is the answer to the question 2400? > David I'm not Austin, but I'll speak up. Yes, you got the right answer. Think of native resolution as the highest resolution the scanner can do without interpolation (where new pixels are 'created' by the software). The Epson 2450 can scan at 2400 x 4800 samples per inch. Imagine a row of sensors spaced at 1/2400 inch, which steps across the original at 1/4800 inch intervals. But your image editing program (Photoshop or whatever) can't deal with pixels that are not on a square grid. To use the 2400 x 4800 scan the scanner software has to interpolate to 4800 x 4800, by 'inventing' the missing pixels by averaging the neighbouring pixels. If you tell the scanner to sample at 2400 x 2400 the sensors step across the original at 1/2400 inch intervals, and every pixel is 'real'. Native resolution. Peter Marquis-Kyle [Non-text portions of this message have been removed]
Thanks you, Austin & Peter.
2002-06-07 by Bob Frost
Peter, From the Epson info that I have read, the 2450 has a 6-line alternated sensor with 61,000 sensor elements. So the sensor elements are presumably spaced at 1/1200 inch with alternate lines staggered to fill in the missing elements by interpolation. You can't escape interpolation it seems, even at optical or native resolutions! Or have I misread the info? Austin will know! Bob Frost.
----- Original Message ----- From: "Peter Marquis-Kyle" <petermk@...> > The Epson 2450 can scan at 2400 x 4800 samples per inch. Imagine a row of > sensors spaced at 1/2400 inch, which steps across the original at 1/4800 inch > intervals. But your image editing program (Photoshop or whatever) can't deal > with pixels that are not on a square grid. > > To use the 2400 x 4800 scan the scanner software has to interpolate to 4800 x > 4800, by 'inventing' the missing pixels by averaging the neighbouring pixels. If > you tell the scanner to sample at 2400 x 2400 the sensors step across the > original at 1/2400 inch intervals, and every pixel is 'real'. Native resolution.
> Peter, > > From the Epson info that I have read, the 2450 has a 6-line alternated > sensor with 61,000 sensor elements. So the sensor elements are presumably > spaced at 1/1200 inch with alternate lines staggered to fill in > the missing > elements by interpolation. You can't escape interpolation it > seems, even at > optical or native resolutions! > > Or have I misread the info? Austin will know! > > Bob Frost. > Hi Bob, Well, sorry to disappoint you, but I don't know! If it's interpolated, then it isn't really "optical" resolution... The spec sheet says "Color Matrix CCD line sensor"...what ever that is...and it does also say "Optical Resolution 2400 dpi", which, if what you say is true, their spec isn't accurate IMO. I'll see if I can find out what sensor it actually uses, and see if I can get a spec on it. But, for $400 it's a very amazing scanner... Regards, Austin
Bob Frost wrote > From the Epson info that I have read, the 2450 has a 6-line alternated > sensor with 61,000 sensor elements. So the sensor elements are presumably > spaced at 1/1200 inch with alternate lines staggered to fill in the missing > elements by interpolation. You can't escape interpolation it seems, even at > optical or native resolutions! ...and Alan Zinn wrote > In the case of the E2450 I have not seen an improvement above 1800 - I don't > know if that is "native" or not. For what it's worth I have a review of it > on my web page. Which all goes to show that, when I tried to explain 'native resolution' I assumed too much. I don't quite agree with what Bob says, though it's a small quibble. In scanners with multiple lines of staggered sensors I think the quality might be degraded by each sensor sampling too large an area of the original, rather than by interpolation. Whatever the theory, Alan's practical observation of 'no improvement above 1800' is the interesting one -- that is, that results are better than you'd get with a single 1200 spi sensor, but not as good as a 'real' 2400 spi one. Still, in comparison with its elders and betters, the Epson 2450 sounds like terrific value for money. I don't regret renouncing the darkroom, but maybe I shouldn't have got rid of my 4x5 camera.... Peter Marquis-Kyle
Austin,
I shall treasure that reply and put it in a folder of its own headed "What
Austin doesn't know"!
I'm not quite sure how we got into this discussion on the B&W list (I had to
look twice to see what list we were on), but since we've started we might as
well finish:
The line I quoted is in the Product Specifications (and copied below):
CCD 6 line alternated with 61,200 pixels CCD
61K pixels over 6 lines gives 10200 per line, which over an 8" scanning
width gives just over 1200 pixels per inch.
I seem to remember an earlier fuss because Epson was using staggered lines
of sensors and claiming higher resolution (just as Fuji do with the S1?).
It will be interesting to see what you find out.
Bob Frost.----- Original Message ----- From: "Austin Franklin" <darkroom@...> > Hi Bob, > > Well, sorry to disappoint you, but I don't know! If it's interpolated, then > it isn't really "optical" resolution... The spec sheet says "Color Matrix > CCD line sensor"...what ever that is...and it does also say "Optical > Resolution 2400 dpi", which, if what you say is true, their spec isn't > accurate IMO. I'll see if I can find out what sensor it actually uses, and > see if I can get a spec on it.
2002-06-07 by Alan Zinn
would be?
>Thanks again
>David Aschkenas
Guys,
In the case of the E2450 I have not seen an improvment above 1800 - I don't
on my web page.
AZ
Maker of Lookaround panoramic camera.
http://www.panoramacamera.us
or
keyword.com lookaround
