Re: [Digital BW] Re: Polaroid 120 Fingers of Death 16bitScans
2002-06-14 by Mike Bragg
Thanks Bruce- Thanks for confirming that is most likely a problem with my scanner. I actually talked to another at tech support and they suggested sending it back for an exchange. I don't mind the noise when scanning its just when im trying to sleep and my powered off scanner is ticking. thanks again photo734 wrote: > Mike, I've had a Polaroid Sprintscan 120 for the better part of a > year and have had no problems--Especially No ticking, although it is > a bit noisy when scanning. Whines and groans a lot! I usually scan in > 16 bits B&W with Silverfast 5.5. I invert in PS then adjust levels > before switching to 8 bits. Most often the image is fairly light in > 16 bits before adjusting levels or curves. Fingers of death on a raw > scan indicate a problem I've never encountered. I'd keep after tech > support it may be a stepper motor problem of some kind. > > Bruce McElhaney > McElhaney Portrait Studio > Livonia, MI > > > > > > > --- In DigitalBlackandWhiteThePrint@y..., Mike Bragg <art@m...> wrote: > > > Hi there- > > > > I just got a polaroid 120 scanner and was appreciate some feedback > from > > other owners on the list concerning a few problems I've been having. > > > I'm using version 1.33 of the firmware hooked up to powerbook G4 via > > > firewire: > > > > 1- For the first week or so my 16 bit b&w scans in polacolor > produced > > smooth histograms however now it seems that the same exact > (correctly > > exposed) negative scans, using the b&w negative/adobe rgb profile at > > > 4000 dpi scanned at 16 bits in polacolor are displaying jagged and > > death finger histograms and subsequently print with micobanding. > > > > 2. I tried scanning in silverfast, which I previously used with a > nikon > > 4000 but when i scan in 16 bits all my scans come up ghost white. > Also > > it looks like you cant do any corrections when scanning in 16 bits - > > > With the Nikon I was able to correct in Silverfast and still scan > at 16 > > bit grayscale. > > > > 3. When the scanner is powered off it ticks - It sounds almost like > a > > clock. When I unplug the scanner the ticking stops. > > > > I did try technical support but there answer was to just scan in 8 > bit > > grayscale. Gee thanks. If anybody with the scanner that has had the > same > > problems or not (maybe something is wrong with my scanner) has any > > suggestions I would appreciate it > > > > thanks > > Mike Bragg > > > Please visit the Group Homepage to check the Files, Bookmarks, Polls > and other resources as they are often being updated. The page is at: > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > > Please follow these basic guidelines: > - Include your full name with your message. > - Include the address of your website, if you have one. > - As threads develop, trim off excess portions of earlier messages to > keep them short. > - As the topic of a thread changes remember to change the subject > header. > - Good manners are required at all time. No personal attacks or > "flames." > - Complete your Yahoo profile. > - Before posting a question, search the message archives and the > various resources on the homepage. > > > > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed]
