Paul,
Thank you for the very good post about the nature of the RGB separation
curves used with the VM inks and your suggestions on how to make
adjustments. I have added your post to the Files section in folder:
Files > Ink Sets > MIS > MIS Variable Mix
As you and I have discussed, there may be a possibility that a reduced gamut
toner for the VM will require less radical curves in the "mw" and "wm" tonal
ranges. I know you have a ways to go before you finalize your non-warming
toner but can you give us some info on what you have tried so far? Warming
aside, I would like to give the set a try with the reduce gamut toner. Can
you share your recipe for the new toner in the M and M+ position for the hex
printers?
Martin
Sent: Wednesday, June 19, 2002 9:29 AM
Subject: RE: [Digital BW] MIS VM-sepia -- hextone neutral prints
> The vm-sepia inkset uses the same "densities" as the standard MIS-VM
inkset.
> As such, I hoped that the curves that currently existed would be at least
> close. In fact, you can see the posted scan of the Epson 870 vm-s test
> strips that used the standard MIS VM curves for that machine -- they are
> close, with no significant flat spots or posterization. They are a bit
> darker than the standard MIS VM test strips, but well within a useable
> range. So, the first thing to check if the vm-sepia inkset produces bad
> results with all the standard vm curves is the settings in the driver.
> What I have noticed most is that the standard MIS VM "warm" curve -- which
> withholds the toner -- often does not work as well as the other standard
> curves. By withholding the toner, the vm-s prints should be relatively
> neutral.
> The reality of these -- and no doubt most other -- inks is that while the
> densities of the vm-sepia match those of the standard MIS VM inks at one
> point, they may not match at another level of application. That is, the
> response curves of the two inksets are not completely linear. I suspect
> that because of this, the more radical the curves, the more likely that
> non-linear responses of the inks on the paper will show up.
> Many of the MIS VM "warm" curves I've done have very radical "green"
curves
> that totally withhold the toner until absolutely necessary to "turn on"
> black ink. While this often works for the MIS VM inkset (depending on
> whether the particular driver can handle that steep a curve without
> artifacts), it can result in less-than-optimal tone distributions in the
> vm-sepia inkset (midtones that are too cool and make the shadows look
> warm -- which they are), and sometimes -- but not always -- uneven density
> distributions.
> With my quad printers (1160 & 3000) I get very nice "neutral" curves by
> putting some sepia toner in the mix all the way. The resulting prints are
> dead neutral (X-Rite spectrophotometer readings: c=m=y) in the midtones,
> rolling off to the paper white in the highlights and black ink warm (y = c
> 0.03) starting at about 75%.
> The 870 is the first hextone machine I've tried to adjust, and I must say
> that the neutral curve did not end up quite as nicely as I would have
liked.
> The shadows get slightly warmer than they do with the quadtone machines,
> with a peak of about 0.04 units warm at 90%. For example, the 870 neutral
> curve I made has X-Rite readings at 90% as follows: c=1.38, m=1.41,
y=1.42.
> This is OK, but will get more so with warming. For example, in the fade
> test currently being done with this inkset, after the first 100 hours the
> 90% warmth was up to 0.05 units. (70% was dead neutral.)
> (A new "non-warming" toner has knocked 0.01 units or warmth off the 90%
> point at start and at 100 hours, but we'll just have to see how it looks
> after much more testing. The "non-warming" (really just more stable over
> time) toner has a slightly lower gamut, but still has very ample tone to
> make full sepia prints.)
> So, what I have found, in general, is that making a curve that is between
> the "warm" and "mw" curves usually makes for better "neutral" vm-s prints.
> However, the hextone machines may not do quite as well at the neutral end
of
> the spectrum as do the quadtone machines. See the 870 vm-s test strips
that
> are posted. Go to the Files section of this forum:
> Then follow the links to
> Ink Sets > MIS > MIS Variable Mix > MIS VM Neutral-Sepia. The image is
> called, "VM-Sepia-Standard 870 v. 1 curves.jpg."
> To make a better neutral curve for the vm-sepia inkset, start with the
> better of the "warm" or "mw" curve and move the "green" (toner curve)
> points -- very little if at all in the deep shadows, but so that they roll
> off to close to horizontal by about the 50% point, but still not at the
top
> of the curves box. For each green point that is moved, for example, up if
> starting with the "mw" curve, move the blue point curve that many points
> down to offset the density change. The blue curve ink (yellow ink
position)
> in a hextone vm machine is the lightest gray ink. It is a hair lighter
than
> the dark toner, and a bit darker than the light/photo toner (green ink
> curve/magenta ink position). So, offsetting moves keep the densities
about
> right. Some final tweaking will be necessary. Print 21-step test strips
to
> see the results of moves.
> These Photoshop adjustment curves can be a bit tricky. For those who have
> not worked with curves, you might want to check out how the vm-s inkset is
> working for others with the machine you have before diving in.
> The vm-sepia is what I use as my regular inkset in the 3000, and I'm very
> pleased with it. However, with other machines, there may not be curves
that
> have been fine-tuned for this inkset.
> Good luck.
> Paul
> http://www.PaulRoark.com
> Please visit the Group Homepage to check the Files, Bookmarks, Polls and
them short.
"flames."
resources on the homepage.
