Different ink usage...
2002-06-30 by André Vallejo
I've been using MIS VM-Inks with a MIS CFS for a while now. Very good
results. But I've been noticing that the black ink bottle empties MUCH
faster then the other three.Actually,the other three are almost at the same
level since I started...
The lines are feeding normally when I run cleaning cycles or turn the
printer on,,I'm printing RGB files with the driver's "Color" setting. What\ufffds
up?
Andr\ufffd
Re: Different ink usage...
2002-07-01 by tomoc
Andre-
If you are worried about it, you can see from a purge file or even a
simple nozzle check that all the colors are spraying correctly.
I use black up about 2x the rate of the other colors, but I'm sure
different images or styles use ink differently.
If you like the prints...party on...
Tom O'Connell
TomOC@...
www.thomasoconnell.com
--- In DigitalBlackandWhiteThePrint@y..., André Vallejo <avs@p...>
good
MUCH
the same
setting. What´s
> up?
> André
2002-07-01 by André Vallejo
Ok,you\ufffdre probably right...nozzle checks are ok,so are purge prints...
Andr\ufffd
> Andr\ufffd,
> Probably nothing. The inks just don't get used up at the same rate. I find
I
> use Black and Yellow more quickly than the others. Very dependent upon the
> general nature of your images and your personal tastes in printing them. I
> would not be concerned about it if you are happy with the results you are
> getting.
> Martin
> Andre-
> Cheers,
> Tom O'Connell
