RE: [Digital BW] paper slipping
2002-07-01 by David Myers
Have you tried to put cardboard the same size of the paper right behind it? This sometimes helps with the loading. The cardboard needs to be thick enough so that the printer doesn't try to feed it instead of the paper. David Myers
-----Original Message----- From: Bill Agee [mailto:billagee@...] Sent: Monday, July 01, 2002 2:37 PM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: [Digital BW] paper slipping Have been using some heavy coated paper...Hahnemule Photo Rag 308 in the 1270 with MIS inksets. After the first cartridge went through, it seems the platen or whatever the intake wheels are called is starting to slip and I have to take each sheet and give it a nudge to go through. I suspect that the culprit is the coating put on the paper to keep the ink from soaking in. Any suggestions on how to clean the paper intake mechanism and wheels to get it back going again on it's own? I set the paper setting to + (plus) to allow for this thick paper. Bill Agee -- b i l l a g e e s t u d i o c a p i s t r a n o b e a c h c a l i f o r n i a billagee@... http://www.redsilver.com Please visit the Group Homepage to check the Files, Bookmarks, Polls and other resources as they are often being updated. The page is at: http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint Please follow these basic guidelines: - Include your full name with your message. - Include the address of your website, if you have one. - As threads develop, trim off excess portions of earlier messages to keep them short. - As the topic of a thread changes remember to change the subject header. - Good manners are required at all time. No personal attacks or "flames." - Complete your Yahoo profile. - Before posting a question, search the message archives and the various resources on the homepage. Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
