Re: [Digital BW] VM Ink tones
2002-07-02 by Martin Wesley
Dave,
Since you started out with a fresh CIS you probably purged the nozzles with
the first nozzle check. The 1160 doesn't hold much ink between the cartridge
and the nozzle.
If you are not getting the variations in hue, then go back and double check
all your settings in the driver to match Paul's workflow. See:
http://www.inksupply.com/index.cfm?source=html/workflow_roark.html
(If the address line wraps don't you will have to cut and paste it back
together.)
I believe Paul's very cool image was probably done with one of the cold
curves which got dropped from development since they did not seem to get
much use. Contact Paul directly and see if he can send you the last version
of the cold curve for the 1160 or perhaps someone else can send it to you. I
only have the 1280 curves.
Martin Wesley
http://www.borderless-photos.de/guests.html
Sent: Monday, July 01, 2002 3:50 PM
Subject: [Digital BW] VM Ink tones
> Its been a while but I'm back.
> I just installed the VM Ink set with new cartidges and
> components for the bulk ink system. I had been using the FS
> inks. This is on an 1160. I purchased the inks about 6 months
> ago but never used them. Downloaded the curves from the MIS
> web site... etc.
> My question is one of tones to expect. After many (25ish) purge
> pages and 15 to 20 8x10 prints, I don't get the warm to cool shift I
> was expecting. The cool curve is cooler, but not even close to
> "Blue" like on Pauls web page. Actually the warm curve to cool
> curve test prints are not that far apart.
> Am I doing something wrong, not yet purged of the FS in the
> heads, or expecting to much?
> Thanks for any pointers,
> Dave
> Please visit the Group Homepage to check the Files, Bookmarks, Polls and
them short.
"flames."
resources on the homepage.
2002-07-02 by Jerry Olson
I get 4 very distinct tones with the VM inks. Possibly you have a
setting wrong somewhere. Or it could be the paper you use. You can use
the cold curve, and slide the magenta slider all the way to the right,
and you will get it quite blue. (The Magenta position bottle is pretty blue).
Jerry
> web site... etc.
> Dave
> Please visit the Group Homepage to check the Files, Bookmarks, Polls and other resources as they are often being updated. The page is at:
> - Good manners are required at all time. No personal attacks or "flames."
> - Before posting a question, search the message archives and the various resources on the homepage.
