Help with clogging on an Epson 1200 with MIS VM ink
2002-07-13 by Tom Moore
Hello all As the subject states, I have an Epson 1200 that I am using with a CIS from NoMoreCarets and VM ink from MIS. I'm also using Paul's workflows. My problem is that the black ink keeps clogging when I leave the printer unused for a day (or sometimes just over night). Cleaning cycles will not remove the clogs. The only method is to put windex on the parking pad and leave the printer for 6-10 hours. Then the clogs go with a few cleaning (sometimes zero) cleaning cycles. So I do have a method that seems to work, but it seems that I have to have many more applications of windex than I would expect and much more frequent than normal cleaning cycles. I've tried leaving the printer on and off when not in use, to no significant difference in behavior. I use the power button, of course. Does anyone have any suggestions as to what I might do reduce the clogging? Tom Moore tom@...
