Re: [Digital BW] Re: My workaround for the PS6 -> PS7 posterization problem...
2002-07-13 by Martin Wesley
Sent: Saturday, July 13, 2002 8:12 AM
Subject: [Digital BW] Re: My workaround for the PS6 -> PS7 posterization
problem...
> --- In DigitalBlackandWhiteThePrint@y..., "coveylaw" <brad@c...>
> wrote:
> > Sounds great, but i don't have PS6-just PS7.
> > Any thoughts.  I am very frustrated with the posterization and it
> > makes my prints unacceptable.
> > btw has anyone tried nik color efex! to convert to b&w?
> So someone else IS getting posterization.
> The real answer is to simply have the curves redone by Paul or whoever
> is handy with a spectrophotometer. This is a lot of work for all the
> pritner/OS combos though. The curves should be redone in Adobe98
> rather than sRGB. I'd respect Paul he he refuses to go through it all
> again.
Jim,
Then what would happen to all the people who do not have this problem? This
is something that is showing up in 1 or 2 systems so far, redoing the curves
would only be justified if the problem were universal.
> He might be able to do it with a transfer curve, I don't know. He
> hasn't responded to any posts on or off list from me on this topic,
> unless I missed it.
> Also, there is still the unresolved issue of whether I get
> microbanding even using Adobe98 with PS7. I can't test it right now
> any further, as I'm short on ink to squander. My test print also still
> shows just a tiny bit more posterization in PS7 vs PS6 when using
> Adobe98. And of course the tones are different using this space. It's
> really crying out for a curve tweak.
I am printing just fine from PS7 on my 1280. No microbanding and the quality
is unchanged from PS6. Any tweak would then give me and everyone else
trouble. Why not tweak the curves yourself for your own use?
> Then the other solution is to just use PS6 until the 2200 comes out
> and go for it. That is a big unknown as well.
BTW, I have seen some B&W 7600 output which uses the same inks as the 2200.
The results are similar to the 2000P. Odd tonal splits and a print that is
fairly neutral in tungsten lighting is yellow/green in daylight. I don't
know if these were good or poor examples of what the machine can do. I want
to see some more but if what I saw is "good" then I doubt you would be happy
with the hue or metamerism.
> You could buy an older computer and network it up on the OS of your
> choice with PS6 and dedicate the printer to it. A bit of bother there.
Since I can't duplicate your problem using very similar equipment (I think
the only difference is that you are running Win98SE and I am on Win 2000), I
would urge you to continue to look for something in your set-up that is not
quite right.
Martin
2002-07-13 by jimhayes361
--- In DigitalBlackandWhiteThePrint@y..., "Martin Wesley"
<mwesley250@e...> wrote:
> From: "jimhayes361" <jimhayes@j...>
> To: <DigitalBlackandWhiteThePrint@y...>
posterization
> problem...
it
whoever
all
> > again.
> Jim,
problem? This
the curves
Well, true. We haven't asked everyone to do the test where you do the
gamma 2.2 to sRGB conversion in each version and write down the
hitogram mean, SD and median and see if they differ a little. It did
for all of us involved in the discussion so something is probably
happening-
OTOH, you would then be right to question whether the amount of
difference affects the actual print. So far only I and apparently
coveylaw see a real difference on the print.
But let's say that a good samaritan has lots of time and patience and
prints out a step wedge in  PS7 AND, and this is important, uses the
space Adobe98 this time instead of sRGB for his (her) curve
generation. Now the corrected curves will give the same values as the
old sRGB curves did in EITHER PS6 or PS7. Therefore it is a useful
thing to do since 1) the better color space is now used instead, 2)
the tones are corrected for using the new color space so it matches
tones when the old sRGB conversion was used, 3) it is indeed more
universal...everyone can use it, whether in PS6 or PS7 with less error
in conversion. Whether they had a problem or not originally, it would
work for everybody, since it now uses Adobe98 space- which gives
almost identical results in PS6 or PS7 (barring that strange
microbanding I had and a bit more posterization which so far I haven't
gone further to investigate).
Should Paul be asked to do the pushups? Only if he wants to. He's done
alot already for us. And it does depend on how many others are
affected by the discrepancy how important it is to switch to Adobe98
officially for all the curves.
topic,
> > unless I missed it.
now
still
It's
quality
else
> trouble.
Not if the tweak gave you identical tonal results- just using Adobe98
instead of sRGB. All I'm saying is keep the output the same, just
strengthen the reliability of the output by changing the workflow such
that the conversion is to Adobe98 instead of sRGB. Paul shoots for the
same step wedge- just with the Adobe98 conversion. In fact, on the MIS
site he has already done this for the 1270 and a couple of others- and
the 1280 if used with a MAc, if memory serves.
At least one other person is having trouble, that's why I responded to
this post.  If you are using sRGB as your conversion space and you try
a relatively dark print and you have a PC- well then I guess you DON'T
have a problem, what can I say.
If then you are happy with things as they are, then sure, keep on
trukin'. Having mutiple curves, PS versions, and spaces for Paul's
workflow might get a bit confusing for me though, ie, "try this in PS7
and if it posterizes try PS6, or, maybe just convert to Adobe98
instead of sRGB, unless you get banding..."  I'm just after
standardizing the curves as much as possible, probably to Adobe98, but
maybe this just isn't possible.
This is a really good idea, and probably the best advice to give
anyone using MIS VM with all the variables of paper. I think we can
fairly say that now just two people are starting to see a new
variable...using PS6 vs PS7.
But using one's own tweak, the correct values can be arrived at. The
only problem is it may take quite a bit of trial and error to get the
tonal changes even. Right now it's easier to just go back and use PS6.
out
the 2200.
that is
don't
I want
be happy
That is discouraging, you would think that Epson would know they have
to give everyone else a run for the money...all those $$$ carts should
print out something worth printing, oh well...thanks for the advance
opinion Martin. I ordered up a sample print from Blair (tssphoto) and
I'll have a look for myself too.
your
there.
think
2000), I
is not
> quite right.
Yes, I will do that after two weeks or so. Thank you for all your
generous help in trying to isolate the problem last week or so. I can
use PS6 for now on my main machine. I don't need to add another
computer myself. Again, you see, I was only responding to "Coveylaw"
with possible options- he has MAC OSX I think.
Jim H.
> Martin
2002-07-13 by Ricardo Lagos
I am a bit confused by the discussion .. so let me state what my setup and
workflow looks like -- it doesn't seem to be the same as the one eveyrone
else is talking about
OS: MacOS X
Scans are done to Grayscale (2.2 gamma) tif files .. (using vuescan) from a
Canon fs4000 (35mm) (16 bit scans)
All manipulation is done in the GS 2.2 gamma space. using PS7
Using PS6 i convert to RGB (adobeRGB -- per the new PaulRoark workflow) (for
a 1270 printer)
Back to PS7 - apply curves (i like the nw curve) ...
print on 1270 using MIS VM-----------
this solved the posterization i was getting -- which i belive was caused by
the translation of GrayScale to adobe RGB by PS7..  (the thread i think was
talking about translating Greyscale to sRGB -- which i was not doing)
-- ricardo
2002-07-14 by jimhayes361
I'm sorry- I didn't see that you were using an 1270- which uses
Adobe98 already. So that renders my other post about sRGB not
applicable.
I am troubled though that you can detect posterization with a
conversion to Adobe98, as it is much less of a discrepancy than sRGB
creates from PS6 to PS7. It means that even a small change in the file
conversion engine shows up visibly for you. I hope I'm not correct in
that assumption. I had a tiny amount appear myself when I used Adobe98
on my Win98SE/1280, enough to make me prefer PS6 over 7 for printing,
but barely. So this makes two of us, but it is apparently much worse
for you. I can live with mine, although I seem to have an odd
microbanding fluke to investigate.
In your file where it shows up, if you follow the workflow through in
both PS6 and PS7 what numbers do you get for the histograms in each
for mean, SD, median? It would be interesting to see how big a change
happens. Martin, Carolyn, etc and I were getting no or at most very
tiny discrepancies with Adobe98, a little more with sRGB. Also folks
suggested very good things to check for in the previous thread on this
topic- such things like using "print with preview" in PS7 to make sure
destination space is Adobe98...
Jim H.
--- In DigitalBlackandWhiteThePrint@y..., "Ricardo Lagos"
setup and
eveyrone
> OS: MacOS X
from a
workflow) (for
> a 1270 printer)
caused by
think was
doing)
> -- ricardo
2002-07-14 by Martin Wesley
Sent: Saturday, July 13, 2002 2:47 PM
problem...
> posterization
> > problem...
(snip)
> problem? This
> the curves
> happening-
Jim,
I feel a bit dim at times. The conversion between the PS6 and PS7 are easy
to compare. Just take the same 2.2 grayscale wedge file and convert it to
sRGB in each and then measure the results with the eye-dropper tool.
The sRGB conversion matches exactly in both versions of PS except at one
point, 95%. At this point the PS6 conversion gives 10,10,10 and the PS7
version gives 5,5,5. I did the same converting to Adobe RGB in PS and PS7
and they match at all points. I have posted a pdf file showing the
comparisons in folder:
Files > Message Related Files > 07_2002 uploads
I will be interested to see if you get the same values if you repeat the
exercise. In theory these should be system and OS independent.
I don't think that we should count on him. He has done more than his share
by far and doesn't even own a 1280. It is time for all the curve slackers
(which includes myself) to take the plunge and start doing their own RGB
separation curves and sharing them just as Paul has done. I will be happy to
host any and all curves in the Files section.
> topic,
> > > unless I missed it.
> now
> still
> It's
> quality
> else
> > trouble.
True, if the tweak is to convert everything over to AdobeRGB then I would
see this as a step in the right direction. The trend now is to apply the
curves in Adobe RGB space and to print with the Epson driver's color
management turned off. This makes the curves much less printer and OS
specific. The Dan Culbertson RGB soft proof method. A lot of work to go back
and redo all of the curves done in sRGB and with the original workflow but
probably worth it.
I am not seeing it in at the print level. Not a difference in the versions
of PS or between sRGB and Adobe RGB with the same file. I do realize that if
I tried the same thing with a different print I might get a different
result.
I certainly agree on standardizing and having to shift back and forth
between PS6 and PS7 does not seem like a reasonable solution. The more
curves the better though. I have found that a change of curves or blending
two curves will often get me out of a posterization jam.
Along those lines when I look at how close the conversion results of Adobe
RGB and sRGB are and how close the PS6 and PS7 conversions are (at least on
my system) my instinct is that you would have a tough time tweaking in such
small differences.
> out
> the 2200.
> that is
> don't
> I want
> be happy
Well it is a single sample and if you see something different, please let me
know. B&W aside I am interested in one to replace our 1270 for color
printing.
> your
> there.
> think
> 2000), I
> is not
> > quite right.
Got it. I seem to recall you are off on vacation and I assume with camera at
hand so good shooting.
Martin
