Re: [Digital BW] Re: Apple Studio Display 17-inch flat panel question.
2002-07-18 by Jeff Magidson
royvharrington wrote: > > --- In DigitalBlackandWhiteThePrint@y..., "martino3847" > <marty@m...> wrote: > > I'm looking for comments from anyone who is using, or has > used the > > Apple 17 inch flat panel monitor for B&W image processing. I > am > > considering purchasing one to use with Photoshop for my > digital work. > > > > Marty Knapp > > http://www.martyknapp.com > > Hi Marty, > > I've been using one for several months and I really like it. > I have a G4 with dual monitor support and I figured that I'd get > the 17 flat panel and keep my older 20 inch CRT. So they are > both connected and the difference is amazing. The flat panel is > much, much brighter, contrastier and sharper. I always use > the flat panel for the image and the CRT just for pallettes > and dialogue boxes. > > Roy A while back I was considering buying an Apple flat panel display. I went to my local Apple store and looked at all their flat panels including the 15", 17", the Cinema display and the flat display on the new iMAC. I made an interesting observation when carefully looking at these monitors! The 15" & the iMac display exhibited a BIG density change when you look at them from different angles on the vertical axis. The 17" and the cinema display do not show this problem. When I questioned the Apple staff at the store he told me that there was no difference between the 15" display and the larger displays except their size. This does not add up! They had a few of each size display set up in the store and they all where consistent with my findings. There certainly is a difference in these displays besides the SIZE difference! -Jeff
