Re: [Digital BW] Re: What defines a "bad" in cartridge?
2002-07-19 by Martin Wesley
Luke, I second Mark on the cleaning issue. Sticking in a set of OEM Epson carts is always my first choice in clearing up a clog that resists standard nozzle cleaning cycles. It also eliminates the printer as the problem. I have had some problem grayscale carts in the past. If the printer works fine with the Epson carts installed, then contact MIS and see if you can get them to replace the carts you have. Martin Wesley http://www.borderless-photos.de/guests.html ----- Original Message ----- From: "markhahn2000" <markhahn2000@...> To: <DigitalBlackandWhiteThePrint@yahoogroups.com> Sent: Thursday, July 18, 2002 5:06 PM Subject: [Digital BW] Re: What defines a "bad" in cartridge? > The pigmented inks are way more fussy so something may have plugged > up, but I have found OEM inks to be wonderful head cleaning aids:) > Windex scares me. I run CIS and save more than the initial > investment almost every week! If you get a good nozzle check it > should be printing fine. > > mark > > --- In DigitalBlackandWhiteThePrint@y..., "Luke Granfield" > <luke@l...> wrote: > > On my second set of MIS VM cartridges for the 1280 I started having > banding. > > Did a couple of cleaning cycles, image improved. Then all kinds of > > weirdness. Very blue image or missing detail, etc. I used a bit of > windex > > here and there :), nothing got better. Finally replaced the > cartridges with > > Epson OEM color inks. After a few cleaning cycles everything great > again. > > Nozzle check runs fine. > > > > Also, the cleaning cycle is *much* shortened when the MIS > cartridges are in > > there, about 20 seconds vs. a minute or so with Epson inks > installed. > > > > My question is: is it possible that something went bad *inside* the > MIS VM > > cartridges? > > > > Thanks, > > > > Luke > > Iowa City, IA > > > > Please visit the Group Homepage to check the Files, Bookmarks, Polls and other resources as they are often being updated. The page is at: > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > > Please follow these basic guidelines: > - Include your full name with your message. > - Include the address of your website, if you have one. > - As threads develop, trim off excess portions of earlier messages to keep them short. > - As the topic of a thread changes remember to change the subject header. > - Good manners are required at all time. No personal attacks or "flames." > - Complete your Yahoo profile. > - Before posting a question, search the message archives and the various resources on the homepage.
> > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ > > >
