Re: [Digital BW] B&W with ICE
2002-07-23 by Tina Manley
At 12:30 AM 7/23/02 +0000, you wrote:
>Someone please correct me if I'm wrong, but this is how I understand it to
>work:
>The use of ICE involves a separate infrared scan. The base and dye clouds in
>colour film (and chromogenic B&W) pass infrared light, dust particles block
>it. ICE uses the difference between the infrared scan and the colour scan to
>automatically "spot" out the dust particles and surface defects. With colour
>films this works very well; the images are free of dust and often show a
>subtle smoothness from the removal of surface defects. Previous versions of
>ICE softened the images slightly, but with the 8000 there's no loss of
>sharpness.
>Conventional B&W film is to varying degrees opaque under the infrared scan,
>and ICE'd B&W negs tend to turn out very contrasty, almost like lith film.
I was told that the ICE software reads the silver in conventional B&W film
as dirt and tries to remove it.  That results in a very contrasty, unusable
scan.
C41 process B&W works great, however.  It scans beautifully with the ICE
turned on.
Tina
Tina Manley, ASMP
http://www.tinamanley.com
images available from:
http://www.pdiphotos.com
http://www.mira.com
http://www.agpix.com
http://www.newscom.com
