Methods of Selection Narrow ranges...?
2002-07-28 by lyonscox
I was wondering what methods people are employing when trying to
adjust the contrast of a narrow tone range, say 5-20%?
To state it another way...if I were to make a traditional silver
print and wanted to do this, I would be doing a dodge/burn in very
specific areas (if using a variable contrast paper, yuck ;-) I would
use a different filter from the main exposure) and afterwards do
localized reducing (most of you call it bleaching).
I've found myself
A - adjusting curves, generally and repeatedly in small increments.
B - selecting areas, layer color fill (~25-75%B) set to burn, etc.
C - using the intuitive dodge & burn tool
OThers?  Efficient?
Cleavis
Re: Methods of Selection Narrow ranges...?
2002-07-28 by antonisphoto
Cleavis,
Your methods A and B are good; C is for "quick-n-dirty". You can select
ranges using the Selective Color command, too, but beware what happens to
the borders.
Basically, there are 2 ways to isolate narrow ranges: By area and by tone. If by
area, you build selections whether manual or automatic. If by tone, you work
with curves.  The trouble with all this is how to fix the range you want without
"breaking" the ranges next to it. The safest and most time consuming way is to
make a manual selection and use that as a mask for a curve.
So, for starters, you should consider a high-bit workflow if you are not using
layer calculations.  Do as much as you can there. Then, in 8bit,  you can use
layers so all your curves are editable on a master file and you don't
repeatedly apply a curve to an area that's already been adjusted and saved.
In 8 bit you can also use a layer with a copy of the original image with an area
masked away and then take advantage of the multiply / screen and other layer
calculations. To that copy layer you can also group a curve to control what the
multiply etc command does to the image below.
Beware of banding in smooth subtle transitions over a long distance - add
noise if you have to, but that should be an emergency measure if the result
needs to be faithful to the original neg, like a darkroom print rather than like a
painting.
Antonis
> I've found myself
> OThers?  Efficient?
> Thanks,
> Cleavis
