Re: [Digital BW] MIS VM QuadTone Cartridges not loading in Epson 1280
2002-07-29 by Martin Wesley
Dain, Are you loading the MIS virgin cartridges with the resetable chips yourself or did you buy preloaded cartridges? If they were preloaded, then give MIS a call. If you set them up yourself then make sure the chips are fully seated and parallel with the cartridge. I bought the QB7 chip resetter and always reset the chips just before I put the cartridges in the printer. I have gotten a couple of bad chips, so if you have some extra chips, which I highly recommend, try a different chip. Also try switching each MIS cartridge one at a time with a known good Epson cartridge to find out if it is the color or the black cartridge that is giving you problems. Martin Wesley http://www.borderless-photos.de/guests.html ----- Original Message ----- From: "daintreeriver2002" <workmantx@...> To: <DigitalBlackandWhiteThePrint@yahoogroups.com> Sent: Monday, July 29, 2002 2:29 PM Subject: [Digital BW] MIS VM QuadTone Cartridges not loading in Epson 1280 > Has anyone had any problem loading the T007 and T009 cartridges with > VM Quadtones in their 1280, or had "bad cartridges". I've done the > cartridge replacement very carefully and no charging has begun -- > both control panel lights remain solid. Help! > > Thanks! > > > > Please visit the Group Homepage to check the Files, Bookmarks, Polls and other resources as they are often being updated. The page is at: > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > > If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page. > > Please follow these basic guidelines: > - Include your full name with your message. > - Include the address of your website, if you have one. > - As threads develop, trim off excess portions of earlier messages to keep them short. > - As the topic of a thread changes remember to change the subject header. > - Good manners are required at all time. No personal attacks or &amp;quot;flames.&amp;quot; > - Complete your Yahoo profile. > - Before posting a question, search the message archives and the various resources on the homepage.
> > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ > > >
