Re: [Digital BW] Can't get rid of a clog....
2002-07-30 by Martin Wesley
Akivisuals, Well the first thing I have to say is never, ever, under any circumstances let your printer sit without any cartridges installed. When you leave the cartridges out, whatever residue may be in the nozzles is going to dry out on you causing problems. At this point try some original Epson cartridges. They are great at cleaning out the heads and will confirm proper operation of the printer. The cleaning fluid in the flush cartridges is so thin that it may make it through the nozzles when pigment inks or even dye inks won't. Martin Wesley http://www.borderless-photos.de/guests.html ----- Original Message -----
From: "akivisuals" <akivisuals@...> To: <DigitalBlackandWhiteThePrint@yahoogroups.com> Sent: Monday, July 29, 2002 6:32 PM Subject: [Digital BW] Can't get rid of a clog.... > I've got a clog that just won't go away. I've done numerous head > cleanings and even tried some glass cleaner on the spongy/felt > area under the print head. The nozzle test repeatedly misses on > the same areas where the clog is. When I first flushed the > system out with the flushing cartridges all the bars printed out. > (using the tinted flushing fluid in inkjetmall's flushing carts.) I let > the printer sit for a week or so without any carts in the printer > while I was waiting for the MIS continuous ink system. After > following the instructions installing the system it now shows > clogs. Should I pull the CFS out and try the flushing carts again? > Will that affect how the CFS runs? There was some mention of > introducing air into the system. Thanks. I'd love to figure out how > to get this working. > >
