Re: [Digital BW] digital images
2002-07-31 by Anthony Atkielski
Stephen writes: > Anthony - can you explain "depth of > modulation" to me? I'll using printing for an analogy, since that seems appropriate here. When you print something (for example), each pixel printed is constructed from an appropriate number of pixels in the input file. It is rare that a one-to-one correspondence exists between input pixels and printed pixels, so usually some interpolation takes place. This interpolation reduces the accuracy of the printed pixels as compared to the input pixels; that is, the printed pixels won't represent the image quite as accurately as the original pixels did. Now, if the number of pixels coming in is the same as the number coming out, the loss depends on how well they are aligned. If the number of pixels coming in is less than the number going out, the true capacity of the printing device won't be used. But if the number of pixels coming in is _greater_ than the number being printed, then the interpolation algorithms have more raw data to work with, and the resulting pixels going out--even though they inevitably represent a loss of resolution--are better chosen, providing a cleaner and apparently sharper image that more accurately represents the original, to the extent possible. So the key to printing nice results would seem to be to send in more pixels than you intend to print; and this is actually how it works. However, the principle of diminishing returns rapidly applies. Up to about 1.5x, adding pixels on the input side improves the output noticeably, even with its fewer pixels; but beyond 1.5x, the bang for the buck diminshes, with additional pixels making less and less difference, until it simply makes no discernable difference at all to keep increasing input pixels. Kodak says that 1.5x is a good ratio, and I tend to agree. Superstition leads many to believe that 2x is somehow better, but I've not seen any clear evidence of that. Anything beyond 2x is a waste by just about anyone's standards. Anyway, this principle of getting better output pixels by having more input pixels to choose from is depth of modulation. With more input data, you can represent the output more precisely--your fewer pixels can be better chosen (color and intensity) to accurately represent the pixels that would have been around them at higher resolutions. Nyquist guarantees that you'll be able to reproduce a given resolution with only 2x sampling, but visible image quality often depends on more than just distinguishing between two lines--more information is required to make the lines look nice, and that's where depth of modulation and more pixels come in. However, if you are going to output x pixels, there isn't much point in having more than 2x pixels (in linear measure) coming in, and 1.5x is generally fine. Of course, all of this applies to digital cameras, too. Having extra pixels in the CCD beyond those that you output means that your output pixels will be better chosen, and the image will be cleaner. The greatest (most cost-effective) gains are for just a slight increase in pixels, of about 1.5x. Having ten times more pixels doesn't add enough to justify the cost. Anyway, the extra pixels provide a depth of modulation that can be useful in interpolation, for cleaner output. The difference is visible up to a certain point, then it becomes difficult or impossible to see beyond. All of this gets more complicated with digicams that use Bayer patterns, and digicams with non-square pixels, and printers that use dithering or stochastic screening, but the basic idea stays the same. If you want a demonstration, find a digital image and build a mosaic image based upon it. Start, say, with an image that contains 100x100 pixels, and convert that to a mosaic of 10x10 pixels. On the first pass, use only the centermost pixel of the original to determine the value of the much larger pixel in the output mosaic. On the second pass, use an average of _all_ the pixels in the original replaced by the mosaic pixel to determine the value of the output pixel. You'll see that the second method produces a much more accurate downsampling than the first method, because all the extra pixels provide a depth of modulation that a single pixel sample would not provide in the first method. This is why image-manipulation programs often give you a choice of methods for downsampling digital images, and the different methods yield very visibly different results.
