Re: [Digital BW] Tri-x/HC110 user needs a change
2002-08-04 by Julian Thomas
What scanner/software are you using are you using? I scanned 35mm trix on a
ss4000 with no problems using Xtol.
Julian
Sent: Sunday, August 04, 2002 5:29 PM
Subject: [Digital BW] Tri-x/HC110 user needs a change
> For eons I've used Tri-x (the 400 not the 320 pro) and HC110 dil B
> for 4.5 min in distilled water. Keeping the dev time low to prevent
> highlights blocking and making sure to give enough exposure in the
> shadows.I took up this 'formula' from Adams' The negative and
> Picker's book & newsletters.
> This has worked well for my silver prints.
> I've packed up my darkroom and now that I'm scanning my negs (for
> 1160 quadtone printing/MIS) I find the grain objectionable - it's not
> crisp and it's big.
> Any advice on adjusting my 'formula' or....a change ? I'm not too
> sure about changing to a chromogenic film as on occasion I may still
> want to have a silver print made.
> thanks
> Frank
> Please visit the Group Homepage to check the Files, Bookmarks, Polls and
page.
them short.
&amp;amp;quot;flames.&amp;amp;quot;
resources on the homepage.
I've been using DiXactol for a while - in the one bath 'stand' method i.e. A
+ B in the same bath. Fantastic dev. Not used it on Trix X though.
Julian
Sent: Sunday, August 04, 2002 5:38 PM
Subject: RE: [Digital BW] Tri-x/HC110 user needs a change
> Frank,
> I'm in the middle of experimenting with 'stand development' for taming
> highlights, meaning two bath's where the developer from the first bath
> exhausts itself in the second bath restraining high density's,
specifically
> for scanning with ccd scanners. I'm trying Dixactol because it's
advertised
> to leave grain un-dissolved, allowing high accutance, and adds a stain to
> fill in between the grain and reduce how apparent it is. Supposedly
there's
> just a small speed loss from rated film speeds, unlike the pyro
developers.
> If your interested I'll let you know how it works out.
> Dixactol info is at www.barrythornton.com and is available from
> Photographers Formulary in the states.
> Larry
> From: frankg_photo [mailto:frank@...]
> Sent: Sunday, August 04, 2002 9:29 AM
> crisp and it's big.
> thanks
> Frank
> page.
> them short.
page.
them short.
2002-08-04 by Larry Roohr
Julian,
Have you found a greater reduction in grain by scanning in rgb and choosing
one of the channels where the stain would be most opaque?
Larry
Sent: Sunday, August 04, 2002 10:04 AM
Subject: Re: [Digital BW] Tri-x/HC110 user needs a change
Julian
> Frank,
specifically
advertised
there's
developers.
> Larry
> crisp and it's big.
> thanks
> Frank
> page.
> them short.
page.
them short.
page.
them short.
2002-08-04 by Ken Carney
Frank:  If you used 400 as the speed, the film has probably been under-developed a couple of stops at least (if temp at 20 degrees and intermittent agitation).  I have had good luck with HC110 and TX large format, but the film requires a different exposure index depending on whether development is compressed or expanded (in my case, with TX pro N-2 is EI 100, N+1 is 200 and so on -D76 1:1).  HC110 can be a little soft, so perhaps is not the best choice for 35 or MF.  Also distilled water can cause soft grain.  My 35mm and MF TX negs developed in D76 1:1 scan fine.  I suggest you try bottled drinking water to mix the developer, and try D76 1:1.  Here we have Ozarka brand drinking water.  It is distilled at the plant, and then the exact same amount of minerals are added in every batch.
I too have transited from the wet darkroom.  I tried the Ilford Delta roll films with Ilford DDX, with miserable scanning results.  My current favorite is Kodak Portra b&w.  It appears to be a true 400 speed, sharp, nice grain, and great tonal range (35mm).  The only trick is finding a pro lab with a dip and dunk line to develop it.  Hope this helps.
  --Ken Carney
  Sent: Sunday, August 04, 2002 10:29 AM
  crisp and it's big.
  thanks
  Frank
        Yahoo! Groups Sponsor
              ADVERTISEMENT
  - Good manners are required at all time. No personal attacks or &amp;amp;quot;flames.&amp;amp;quot;
No, I'm too lazy for that! I use Vuescan and scan a Image setting
Julian
Sent: Sunday, August 04, 2002 6:08 PM
> Julian,
choosing
> Larry
> From: Julian Thomas [mailto:julianthomas@...]
A
> Julian
> From: "Larry Roohr" <lrryr@...>
> > Frank,
> specifically
> advertised
to
> there's
> developers.
> > Larry
> > crisp and it's big.
> > thanks
> > Frank
same
> > page.
keep
> > them short.
header.
> page.
keep
> them short.
header.
> page.
> them short.
page.
them short.
