On 8/11/02 10:05 PM, "Todd Flashner" <tflash@...> wrote:
>> I've got a testy image that I need to convert to a BW for quad
>> printing. Lots of trouble with the skin tones. (wedding shot) I read
>> through the posts and got some good ideas. The most interesting seems
>> to be converting the channels into layers via the Jeff Schewe method.
>> How do I do this? Can anyone point me to more info, or describe the
>> process. That is, convert the channels into layers? Is this possible
>> in 16 bit mode? Thanks in advance.
> Since I brought the method up I'll do my best to explain it. It does not
> work in 16 bit mode because it requires layers, which 16 bit does not
> support.
> You can do much of it with keystrokes, but I think I'll explain the long way
> so you see exactly what's going on. Others may know how to do it even faster
> than me. An action would be a great thing for this!!!
> Separate your layers pallet from your channels pallet (drag the tab of one
> out of the window).
> Start with your background layer selected. Go to your channels pallet and
> click on the channel you want to bring over as a layer (I just start with
> Red and work my way down). This should turn off your other channels so your
> image displays as your RED channel (okay, a keystroke... You could just hit
> CMD+1 to select the red channel only, CMD+2=green, etc). Hit CMD+A to select
> all. This is selecting all of the RED channel. You should see the marquee
> around the perimeter of your image. Hit CMD+C to copy the entirety of your
> RED channel. Now click on the RGB master channel (top one). Now click on the
> Background layer in your layers pallet. Hit CMD+V and your RED channel
> should now be pasted in as a layer above your background layer @ 100%
> opacity.
> Now I repeat everything for the GREEN channel. Click background layer, click
> green channel, CMD+A, CMD+C, click master channel, click background layer,
> CMD+V. Then repeat for the BLUE channel.
> You might be able to skip always clicking the master channel and bkgd layer,
> I don't remember, but sometimes I found I'd end up pasting one channel into
> another channel - this routine helps me keep things straight.
> If all went well you will now have the three channels stacked atop of each
> other as layers. Click each "layer" on and off to be sure each one is
> different from the one below, IOW, that you didn't do any more than once,
> and not get another.
> Once they are stacked you can change opacities, stacking order, and blend
> mode, or even use the underutilized "blend if" sliders (double click the
> layers name). You can turn off your background layer at this point, or leave
> it on to mess with a desaturated color look, or whatever else you may
> stumble upon.
> HTH
> Todd
> Please visit the Group Homepage to check the Files, Bookmarks, Polls and other
> resources as they are often being updated. The page is at:
> page.
> them short.
> &amp;quot;flames.&amp;quot;
> resources on the homepage.
