human retina
human retina
2002-09-07 by MARK MAIO
> > > Also, humans have variable resolution in their
> > > sight...
> > No, they do not.  The maximum resolution is set by physiology, as
> > described
> > above.  Some people have less; but nobody has more.
> They do not what?  It's a physical fact that your eye has higher resolution
> in the center, and decreased resolution around the periphery.
My two cents regarding vision. The normal length human retina has only
one small area, called the fovea, where light is in focus in all of us
who do not require contacts or glasses. Eyes shorter or longer in length
require + or - lenses to focus the image at the correct distance. While
the majority of the remainder of the retina is curved and on the same
plane of focus, the center of the fovea is slightly indented and at a
different focal plane. This area is where we do our critical seeing and
where the image is sharp. You are reading these words using the fovea of
your eye. Everything else in our visual pathway is considered peripheral
vision and while we really don't notice it, is out of focus. We have
"learned" to "see" as if everything is in focus.
Other major physical components or problems with our eye which affect
our resolution of detail:
1. The cornea, which is like the glass crystal on our watch, is part of
our optical system. Any defect here (most common is astigmatism),
affects the resolution of detail on the retina.
2. The lens. Most common is our losing the ability to accommodate (which
is to say "focus"). Most of us notice this around the age of 40 when the
"zonules" (which attach to the lens and act as the focusing mechanism),
lose their ability to shape our lens so it can focus at a close
distance. Once our arms get too short (as in I can't hold the book far
enough away to see it in focus), we need to get reading glasses. The
other common age related visual problem is cataracts. The formation of
most cataracts is due to us living longer than we were designed to. As
we get older, our lens starts to harden from the inside center, out.
Think of it like the the optical center of your photographic lens taking
on the properties of frosted glass. The cataract starts as a mild defect
and usually progresses to the point where it (as in your lens), has to
be removed and replaced with a plastic lens. As the cataract is forming
over a period of years, we not only slowly, and without really noticing,
lose the ability to distinguish fine detail, but the cataract also turns
the lens yellow, affecting how we see color. One way to slow this
process down is to always wear UV blocking sunglasses outside.
To qualify the above information, although my formal education is in
photography, my knowledge of the eye has come from working since 1978,
in the field of ophthalmic photography (we photograph the eye, inside
and out, for diagnosis, treatment and research), nine years of which I
held the position of assistant professor in the Medical School of the
State University of New York. And before anyone asks if they should have
Lasik surgery so they can stop wearing glasses, I'll give you the answer
I tell my relatives, which is I don't know one ophthalmologist (and I
know hundreds), who has had the procedure done.
Mark Maio
Re: human retina
2002-09-07 by marktuckerdotcom
--- In DigitalBlackandWhiteThePrint@y..., MARK MAIO
us
Two questions:
1. "Fovea, where light is in focus"; this must be where the digital
chip Foveon gets its name?
2. Not exactly a lazik question, but, I'm 43 years old, and my face
is crammed into a 21" monitor most of the time nowadays. My
doctor says I have "Forty-itis". I've always been freaked about
focusing; if you look into the viewfinder of a Hasselblad (or any
camera), you are not "focusing" on the ground glass, right? You
must be focusing on the distance of the subject.
IOW, I can't see closeup at all. I see faraway fine. If I look through
the viewfinder of my hassie, and I'm focusing on a subject that's
25 feet away, are my eyes "focused" at 25 feet, or are they
focused on the distance to the viewfinder ground glass? (I guess
I know the answer,because I see fine through the camera, even
without any diopters, but a good friend CANNOT focus my
Hasselblad; claims it never "pops" into focus.)
-Mark Tucker
Paranoid 43-year old
http://marktucker.com
