Hawk Mountain Harrier paper?
2002-09-12 by Editor P.O.V. Image Service
Anyone seen or used this paper? I'm interested in a few items: 1) What common papers have a similar tooth or color? 2) What weight and thickness are the 13x19 sheets in? 3) Any warnings on using it with pigment or dye inksets..? I'm currently using: MIS VM and MIS VM Sepia, Lyson Lysonics, Lyson Small Gamuts, and Lyson Fotonics (unlikely I would use the last inkset on the Harrier) in EPSON and Canon printers.. I may be adding the MIS Perpetuals or Gen 4 inkset to the mix over the next month or so.. I wondered if anyone has printed with it and using which inks? Any feedback? In case anyone cares I am looking to potential use of this paper primarily with pigments, while I would probably use the Lanaquarelle paper with dyes.. Given that the Harrier is gelatine coated, I worry that dye-based inksets may bleed in high humidity.. Keith
