Re: [Digital BW] PhotoShop Work Flow
2002-09-12 by Martin Wesley
Val, The big plus of working in 8-bit is the ability to use layers and layer masks to great very precise adjustment layers that can be tweaked individually. There are so many tools available in 8-bit that are not in 16-bit I really can't begin to list them all. I tend to do all the large overall adjustments and large area adjustments in 16-bit and then do all the fine tuning in 8-bit with adjustment layers. The advantage to staying in 16-bit is that you will have more and smoother data to send to the printer. In 8-bit you are more at risk of running into problems with posterization. You don't need to drop into 8-bit to sharpen since you can apply unsharp mask in 16-bit mode. Personally I like to create a second layer in 8-bit that is edge sharpened and using the layer opacity blend it with an unsharpened or very lightly sharpened layer. Basically you sound like you are on the right track. There are just so many different ways to do the same thing in Photoshop there is no "correct" method. Martin Wesley http://www.borderless-photos.de/guests.html ----- Original Message ----- From: "vbrunell23" <vbrunell1@...> To: <DigitalBlackandWhiteThePrint@yahoogroups.com> Sent: Wednesday, September 11, 2002 10:40 AM Subject: [Digital BW] PhotoShop Work Flow > I am a new member and this is my first post to this group. I have > been inkjet printing for about six months. I am using a 1280, CIS > and PiezographyBW and have been quite satisfied with my recent > results and printer "up time" after a tough first few months sorting > out all the normal issues. > > I am still not sure of a few PS workflow issues regarding bit size. > Following suggestions I have seen on various posts, I am doing major > tonal adjustments (levels and curves) in 16 bit mode and then saving > a working copy (just in case!) I then convert the file to 8 bit for > sharpening, if needed, and any final cosemetic fixes like spotting. > I am assuming the major advantage of changing to 8 bit is file size > and speed, as the tools I normally use at this point also work in 16 > bit mode. Are there other advantages to converting to 8 bit? Do I > give anything up by not staying with 16 bit right through to the > printing process, other than the ability to better tweak tonal > values if necessary? > > Thanks, in advance, for any help you can give me with this issue. > Following this group from the sidelines has been a great help in > getting my digital darkroom efforts off the ground. > > Val Brunell > > > > Please visit the Group Homepage to check the Files, Bookmarks, Polls and other resources as they are often being updated. The page is at: > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > > If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page. > > Please follow these basic guidelines: > - Include your full name with your message. > - Include the address of your website, if you have one. > - As threads develop, trim off excess portions of earlier messages to keep them short. > - As the topic of a thread changes remember to change the subject header. > - Good manners are required at all time. No personal attacks or &amp;quot;flames.&amp;quot; > - Complete your Yahoo profile. > - Before posting a question, search the message archives and the various resources on the homepage.
> > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ > > >
