Barry,
You may be right about the clog of the yellow nozzle. Or it may be a
poorly filled cartridge. When you do a nozzle chack, you do not see
any pattern, I presume. If so, you should return the cart to IJM.
However, note that it is not completely uncommon to have a problem of
your sort on occasions. It may be worth letting the system just sit
overnight, and try again tomorrow. If you do so, don't subject your
printer to another 20 cleaning cycles in a row.
If you are new to this, and do not want to risk further problems, I
recommend you remove the WN carts, and replace them with the Epson
OEM dye carts. These inks, I find, are like universal cleaners.
Also wait overnight after changing carts. Try this first.
Good luck - this can be really frustrating.
Shilesh
--- In DigitalBlackandWhiteThePrint@y..., "biw3450" <bwolf@e...>
wrote:
> Had posted a question earlier that I was not getting a good head
> check on the yellow position of my 1280 using Piezotone WN inks.
Just
> printed a 21 step gray scale and the first 30% is all white no
steps.
> I believe that I have a clog or they didn't load up the shade of
gray
> that goes where the yellow head would spray. Since I have cleaned
> heads 20+ times what should I do?
> Any help would be appreciated.
> Thanks,
> Barry
