Re: [Digital BW] Piezotone WN inks
2002-09-16 by Martin Glader
You could try the procedure 9 - MAJOR CLOG from HELL (Fantastik/Windex
Treatment) found on http://www.piezography.com/ts/faq.html under point
3. Clogging issues. I recommend removing the whole printer cover. Only
four screws.
> Had posted a question earlier that I was not getting a good head
> check on the yellow position of my 1280 using Piezotone WN inks. Just
> printed a 21 step gray scale and the first 30% is all white no steps.
> I believe that I have a clog or they didn't load up the shade of gray
> that goes where the yellow head would spray. Since I have cleaned
> heads 20+ times what should I do?
> Any help would be appreciated.
> Thanks,
> Barry
